800+ miles per tank club!!!
Coaster
New England
Nice.
It becomes a game after a while.
A quest for the highest score!
I was in that mindset with my first hybrid in 2005.
Nice.
Absolutely true statement. In the spring I think I'll try for 850 or above but use a calculation to empty.
I don't want to end up in a class saying hi my name is ______. I can't stop driving my Maverick in the city 😁😁
Coaster
New England
I assume by your odometer that your running the stock OEM tires. Which ones? Tires can make more difference than many people think.
Stock base XLT model, no tow hitch yes hard tri-fold cover.
Coaster
New England
I'll drive 900 miles on one tank.
I'll let you ride with me and video record it to prove it happened. I'll even come to Nebraska.
It's a flat state with lots of roads I can pick my own speed on and not see another living soul (or a stoplight) for hours on end.
Then you'll pay me for my time and travel expenses and you'll STFU.
Sound agreeable to you?
I believe you or somebody can do it. Maybe somebody already has.
Coaster
New England
As far as temperature and running the heat because it's cold out makes a big difference.
One pic from yesterday was a cold start call for heat and drive , , gas engine started immediately. About 38°
Other pic with higher MPG about 48°no heat off but vehicle was pre warmed up from short drive.
If above 60°, I could get above 55 MPG every time. Same destination.
Ford Maverick 800+ miles per tank club!!! IMG_20231128_102217300
Ford Maverick 800+ miles per tank club!!! IMG_20231127_093811144
Coaster
New England
So many variables to good gas mileage.
For me City driving would mean around six traffic lights in a given day.
I don't live in the sticks but I can avoid most traffic lights if I choose
GPSMan
Many
During the holidays my MPG went down.
Darn lack of traffic and higher road speeds. 🤓🤔😄
GPSMan
Many
If you run the heat to the cabin on medium to high settings, you can literally watch the temperature needle go down while stopped at a single stoplight.
blackb13
New personal best for a tank. Normal driving to/from work, no hypermiling or other nonsense. Just no HVAC and nearly 100% city traffic. Normal mode.
14.9 gallons to first click at the pump. Went to 0 at 833.6 on my way to get gas.
Ford Maverick 800+ miles per tank club!!! 1000003244
blackb13
So I hit over 800 miles on one tank for the 1st time, and probably the last time unless I have a backup fuel tank with me.
I hit the "0 Mi to E" at 745 miles. From this point I set my Trip 2 to record the mileage after the gauge said I hit 0.
I usually fill up when I hit or are close to the system's estimate of zero miles left. In those cases my fill up would be anywhere between 13.7-14.1 gallons. After seeing a post of someone filling up to 16 gal I thought I would push my luck. I did have a 1 gal back up gas container after I hit zero, but will not plan to do this often. Unless you usually have a rack with backup fuel container just fill up. Not worth pushing it especially since you dont know what driving style you will use for those las 2-2.5 gallons. I made it to 67 miles past 0 so I assumed that I was at bout 15 gal used. I did my usual three clicks at the pump and I assumed wrong.
I used 14.8 gal witch came out to 54.8 MPG on this tank (best ever was 55.7 mpg). I did take the freeways more than I thought I would and I also did a long drive from San Jose to Manteca during rush hour with an accident, about 60 miles one-way 120 roundtrip. On the way back I was not in traffic, so if someone in the central valley has a Maverick and they drive both ways on HY 680 and HY 580 what kind of MPGs and MPT are you getting?
If the tank does actually hold 16.5 gal as on post suggested, the it could be possible to hit 900 miles on one tank, but I wont be trying that anytime soon. I might but not unless the conditions are right and I have time to get out on the side of the road with a filled backup tank.
You should rename the thread title to match the others. "800+ miles per tank club"
Crash11
NA
2024 Maverick XL Hybrid
13.8 gallons is what the MTE is based on in the hybrid and 16.5 gallons is what the MTE is based on in the EcoBoost.
It is what you can reliably count on.
Both trucks have over 2 gallons, I think 2.5 gallons of fuel in the tank up and beyond those published values.
You don't have to mentally keep a reserve, it's built into both the tank size and the MTE calculation. You will not run out of fuel if you drive to MTE 0.
(Imagine the lawsuits and customer back-lash if it were off by one and you ran out at MTE 1. It's not going to happen.)
Official tank capacity in the EPA database is 14.5 gallons. You can certainly squeeze a little more than that in it, but you are risking damaging the evap. canister with liquid fuel.
Just fyi guys and gals, it is never recommended to fill the tank up beyond the first click from the pump handle. The vehicle is likely to develop evap. system faults quicker than designed.
The Real Maverick
Jack
You can pump in ~15.x gallons to the first click.
blackb13
Nah, it's not 14.5. That's been proven over and over again.
Crash11
NA
I'm not talking about what you CAN do. I'm talking about what you SHOULD do.
blackb13
Your original statement reads factual, but it isn't. Particularly when you use words like "never."
You're assuming people are overfilling the fuel system, when they are not. Even if they were going "beyond the first click," how would the system develop faults "quicker than designed?" Do you have intimate knowledge of Ford's evap system design or are you just providing anecdotal evidence?
Genuinely curious.
