r0tax
r0tax
CO
2025 Lobo 402A VB
Yes indeed Ryan, thanks again. I'll make that change soon. I'm confident it will work as you described, exactly as I prefer. FYI, I fueled for the 2nd time today. Had to look closely to find the fuel door release button. Lol.
You mean by pressing on the gas door? lol
I had a Focus prior, and while it shows an obvious 'indent' for your finger to press, it was not obvious which side on the Mav. Thats fine, it looks nicer without the indent, and typically it just takes 1 time to learn where to press. I'd rather it look clean and smooth and be slightly baffled upon first fill up. haha
ryan2366
Ryan
2025 Maverick Lariat - Hybrid AWD
I’m trying to find the wiring for 79 and 80 from the fuse block under the hood.
79 25 A Left-hand side enhanced exterior lighting module.
80 25 A Right-hand side enhanced exterior lighting module.
I crudely ran a wire from the fuse to my 8 switch bank to power it upon returning to my vehicle.
When I open the door it activates powering up the switch. Turns off at some point so it’s not on all the time.
Works great. I’d just rather tie in to the wiring somewhere if anyone figures it out. I’m thinking of running my bed lighting off of it too so I don’t need to start my vehicle.
I suspect I can do that of the cargo lights from the bed as it’s likely on the left hand exterior lighting module.
Next project šŸ˜‰
ryan2366
Ryan
Hybrids have a button with the headlight module
KenE
Ken
Mount Washington, KY
2025 Maverick Hybrid Lariet
No, the 25MY hybrid has a button above the headlight knob. You have to press that button to release the fuel door lock. Previous Fords I've owned in recent years you pressed and released the fuel door from outside to open, as you describe. I assume it's a 2025MY change?? Year-to-year changes keep us guessing. Lol!
r0tax
r0tax
CO
2025 Lobo 402A VB
My '25 Lobo is a 'push the door cover' situation; no button (i looked for a button initially when i got to the pump).
KenE
Ken
Why they didn't make all the trim levels the same regarding fuel door stumps me???
RyuRonin1977
Tristen
Virginia
2025 Ford Maverick
Just updated the spreadsheet with global windows for the 2025. Looks @fcoplo has figured it out as well. I'll add you @r0tax tax to the contributors of the spreadsheet and @fcoplo.
Could I get a read only copy of the spreadsheet? I want to get all my codes together in 1 spot before getting the 2 month license again. Thanks in advance if this is possible
Badluckinc
Indiana
2025 Lobo
Hit me up with that also if someone could please and thank you.
r0tax
r0tax
CO
2025 Lobo 402A VB
You can save the Google spreadsheet locally, if thats what you're after:
File > Download > PDF (or whatever format you want)
Ford Maverick 2025 Maverick Forscan Codes _ Working 1753122365535-x
Been that way since the start - higher pressure in hybrid tanks, they release before door opens. I guess to avoid a potential cooling spray of fuel to the body on hot days.
RyuRonin1977
Tristen
Virginia
2025 Ford Maverick
Wait...is the spreadsheet inside the Forscan that I download? Apologies I am new to Forscan and thought people on here were keeping a spreadsheet of codes and such.
BlueSpec1
Gene
No not in Forscan.
The spreadsheet EONR24 worked up is at: Forscan - Maverick Master List
That's where you can download it if want to:
Ford Maverick 2025 Maverick Forscan Codes _ Working 1753218493779-ry
RyuRonin1977
Tristen
Virginia
2025 Ford Maverick
r0tax
r0tax
CO
2025 Lobo 402A VB
No not in Forscan.
Ty for linking. I also updated my OP with the link to it, and credit to EONR24. I thought I had it there, but it was just credit for the information. Hopefully it helps future Forscan code hunters. :D
