Which Bed Liner?
balucipher
Balu
Coral Springs, FL
2021 Gladiator, 2021 Tesla Model Y
I was going for the drop in but my dealer said it would hold up delivery date so he suggested an after market.
Anyone know of an after market place in Southern California?
search Line-X in google near you and read reviews
asel3121
Asel
South Florida
Camaro
I had the drop-in selected on my specs because I wanted bed protection and took the cheapest option. My dealer explained to me that they can do a spray-on at the dealership for almost the same price as the drop-in, and after hearing how it's more textured and minimizes cargo from sliding around, I agreed and went with that option.
Ken89
Ken
Utah
Honda CRV
I'm just buying a 3/4" rubber horsestall mat (4'x6') for $40 and cutting it to size. Its way more heavy duty than fords drop-in bed mat. Someone earlier mentioned commercial gym mats which are the same material and density.
SgtLip
Donald
Disney World
That might be a good response for someone living in Vegas. Most regions in the US and Canada aren't nearly as arid as your area and wet plywood in most places can lead to several undesirable results (mold, warping, rust, termites, etc.).
Also, if you don't cut the plywood exactly to fit, you will experience rubbing on the bed floor and wheel wells. Any little bit of dust or dirt can absolutely wreck an unlined bed's paint/finish. I had cut plywood for the bed of my work truck several years back and some metal shavings got under it. Needless to say, the boss was not happy with the results.
But if plywood works for you, by all means use it. I'm sure everyone will end up doing what they want to do anyway.
Go to Tractor Supply and get one of their Rubber Stall Mats. Cut it like you would the plywood and you have a bed mat for life.
Kenny
Kenny
2022 Maverick XLT 2.0 Ecoboost with AWD, Tow Pkg
Does anyone know if the spray-in bedliner is color-matched?
As Henry Ford once said, "You can have any color you like . . . as long as it's black."
Dman
Darrell
San Gabriel, Texas
2017 Corolla,1990 Silverado,1949 GMC,1949 Harley
This is what I wanted to do but I thought the bed was 53 in wide and it would bother me that the very edges weren't covered... Probably nothing would be rubbing right there but it still bothers me.
bbhaag
Ordered the Lux package so spray-in was included.
Nighowl2000
Roy
Ottawa
2022 ford Maverick lariat
Dealer did line-x on mine
Ford Maverick Which Bed Liner? IMG_20211103_163431887
kw86er
KW86ER
Vancouver BC
2L XLT FX4
I always beat the crap out of my bed for a couple of years and then get a spray-in bed liner. It's almost like getting a new truck! Remember to get under the box a pound all the dents back into shape first.
Buy 4x6 3/4" stall mat cut off 3" longer than depth of bed. Cut the small piece that was cut from 4x6 piece into two equal pieces keeping the long factory edge. Epoxy those factory edges to the factory edge of the large piece to extend the 48" width to a wider length. You will have an open space between them but that will trim off. Buy a piece of 5mm 4x8 sheet of underlayment from big box.(will be probably thinnest plywood they will have. Rip or have them rip saw it into 6" wide strips. Use these strips to cut into pieces to follow around the bed. You can scribe the edges to follow any contours or off sets to follow where you will want to cut. When all pieces are cut you can tape them to bed floor or weight down with bricks or?. Take unused 6" stripes cut pieces and glue across all cracks between all the original pieces lying around the inside of bed. Then when glue is dry. Remove bricks if any are left and glue 3 or four more strips across the opening in the center of the pattern you have made to stabilize the pattern. If you need to mark any holes or whatever mark them on this pattern at this time if you didn't do that earlier. When all glue is set you can remove this pattern and trace around it to see where you need to cut the piece of stall mat that you so cleverly prepared! Have a good time "flexing" in your bed.🤩. Pattern might be a good garage sell item or ?
jwilson
NJ
PENDING MAV XLT/Hybrid
TheRef
Bruce
Auburn, AL
No liner dealer has non-pigment material needed for color match liner. Going to be months? Has anyone taken the top bed trim off and put liner to wrap around top? Suggestions,?
