Your truck has a system that tells you when to change it. Many people are skeptical, but not a single person has ever proven that it is inadequate.
Enjoy your truck.
So if break-in oil - why would you not use it to the stated break in period at least?Your new car or truck has break in oil inside. For example, a Volkswagen specialist would say you should do your first oil change between 250 to 500 miles to get rid of any metal shavings etc.
So, you started a thread to ask all the “Ford specialists” if breaking in a Maverick is somehow different than what you’ve heard about breaking in Volkswagens?Your new car or truck has break in oil inside. For example, a Volkswagen specialist would say you should do your first oil change between 250 to 500 miles to get rid of any metal shavings etc.
Then there’s the Turbo and on the older ones auto stop/start.numerous threads. Most people recommend between 500 and 1000 miles to purge the factory gunk after it's all washed down into the pan.
And after that, if you are using quality synthetic oil, you really only need to change it every 10k miles; no matter what those old guys who had pre CAD/CAM cars before 2000 say. Things are built different now, not like 1960's and 70's cars that MIGHT get 100k miles before a major engine torn-apart repair. And the syn oil and filters are vastly superior, too. Trust the manual, it's already at overkill replacement intervals, because they don't want to do warranty work.
Bring on the popcorn. Butter please!numerous threads. Most people recommend between 500 and 1000 miles to purge the factory gunk after it's all washed down into the pan.
Go by the factory recommendation.
If I'm not mistaken the OEM oil filter on new Mavericks leaving the factory is kind of miniscule
