What PSI air pressure are your tires?
The Real Maverick
Jack
here’s my issue.
My Dealer does the Nitro upgrade (no choice - part of Dealer Package), but it doesn’t account for altitude. They set it for 32psi in Tucson, but when I get home, (over a thousand feet higher in altitude), my tire pressure is lower (28 - 30 psi).
Wanna check that again and report back????
The pressure in your gauge is the DIFFERENCE between inside and out.
If pressure in the tire stays the same, and outside air pressure drops, the difference in the reading goes UP.
Example : 40 psi while in mountains will be 35 psi at sea level.
Bob The Builder
Butch
Vermont
32 with the Pirellis.
Montana
The pressure that it says on the door sticker.
Is this a trick question?
You'd be surprised how many people don't know this.
They think the max PSI on the tire is what the tire should be set at. I recall a thread on it here where multiple people chimed in and said this.
Personally... I only use 60* PSI... 65 is waaaaaaaay too rough :ROFLMAO:
*In all seriousness, my 245/65R17 KO2's are set at 35
Decayed
yes
a car
I set mine to 36 when I fill them, under the assumption that they will (and they do) slowly bleed pressure over time. When 2 or more hit 34 or lower they get refilled. It's nice having a reasonably accurate pressure meter on the dash although I suspect one of the sensors reads low.
bgn
WA
30 psi, Toyo Open Country III in 245/65R17.
Frenchy
Bert
Taylorsville Utah
20205 Maverik Hybrid AWD 4K town, read
Just checked my tires yesterday. (these are the "Take-offs" from my MAV's brother).
They were at 32psi.
I adjusted them to 35psi.
Noticed on the side of the tire that the max psi is "51" :eek:
Really??
Jerry
A sligth overinfaltion does not hurt anything contrary to underinflation which causes tires to overheat and to "explode". From Michelin school. I noramly run 38/40 PSi
SP1966
Vegas
2024 Maverick XL Hybrid
I've run mine up to 40 but the fuckers drop back to 35 within a week. I've done it a few times now, it's strange how they stabilize around 35 every single time.
Tbone289
MO
I run mine at 37-38 PSI. I adjust pressures on average about once a month, depending on ambient temperature changes.
Kenv24
Ken
2024 XLT
They were at 32psi.
Really??
Jerry
Yes…really. Exactly what it says. That’s the max that should be put into that particular tire. Some people do run the max for several reasons. 😎
Bob The Builder
Butch
Vermont
35 Cold. OEM Pirelli Scorpion ATR
I have a few different air pressure gauges. All of them read different pressures.
Ford Maverick What PSI air pressure are your tires? 20241219_105053
I feel sorry for the folks with OCD chasing the displayed tire pressures.
vinnymac
Vince
I attended ford tire tech school in Dearborn along time ago and the teacher stated ford engineering can try several brands and pressures to get the best overall result. They stated on the vin label you will find the best pressure for handling and ride quality
