How to read tire air pressure?
Guy Johnson
Guy
Deland
2026 Maverick Lariet
How do I read tire pressure on 26 hibred lariet?
Carlitos_92
SafetyGuy
Andy
Manitoba
Good day
Check the manual first, and then look inside the drivers door jamb for your vehicles particular tire pressures to confirm.
When checking tire pressure (with a good quality tire guage of course), make sure it isn't by just using the truck provided pressure readout!
Check your tires when they are cold. This means first thing in the am, normally. Not when the sun is shining on and warming any of the tires and not after driving the vehicle if at all possible.
Be aware that outside cold or warm temperatures will give you varying temperature readings.
Driving will raise your tire pressures as the tires will heat up as you drive along.
Also, you need to put in more air in your tires for winter and possibly let air out/adjust when entering summer weather.
Air expands and contracts with external temperatures so that is why you always check and adjust your tire pressures when they are all cold.
Manufacturers allow for the rise in temps when you are driving so again, set tire pressures when they are cold if at all possible.
Okay, that is enough generic tire inflation info for now.
Have a good one,
Andy
Oandrews
Orvis
South Eastern USA
'25 Tremor
Good day
Have a good one,
Andy
The tires pressure will increase 1 lb for every 10° the air temperature increases.
Meeka
Jay
Castlegar B.C. Canada
2024 XLT 2.0 turbo
From my experience anyway, it increases more than that. I.E. temperature 10 degrees, tires in shade, 35psi, tires in sun, 38psi, they both started @ 35. But… apples, oranges!
Guy Johnson
Guy Johnson
Guy
Deland
I read manual, I am unable to find the trouble shoot on screen. Where do I look?
Trouble Shoot?
Why?
VIEWING THE TIRE PRESSURES
Ford Maverick How to read tire air pressure? imagen2
To view the current tire pressures, use the right front facing steering wheel switches to navigate the instrument cluster menu. The tire pressures can be found under the MyView tab or the vehicle maintenance menu when the vehicle is not in motion.
INFLATING THE TIRES
WARNING: Do not use the tire pressure displayed in the information display as a tire pressure gauge. Failure to follow this instruction could result in personal injury or death.
SafetyGuy
Andy
Manitoba
Good day,
We have very little info to work with in order to try and assist, so I am just going to paste the troubleshooting pages below.
The pdf search function really makes finding things so much easier for me. :)
Hope this helps,
Andy
Ford Maverick How to read tire air pressure? Screenshot_20260403_143502_Samsung Notes
Ford Maverick How to read tire air pressure? Screenshot_20260403_143550_Samsung Notes
Ford Maverick How to read tire air pressure? Screenshot_20260403_143609_Samsung Notes
