Uneven tailgate cables
Snax
North America
I think the most likely problem is it's just the cable(s) cut to a little different length during the rush of production and poor quality control.
Well, that must make it true. Because speculation > data.
Big_T
T
2022 Maverick XL Hybrid
"If most likely problem" = true, I'd say you're the one with a problem. Whatever is wrong with the tailgate will be fixed under warranty, so no real need for further internet diagnosis anyway.
Snax
North America
Wow, who put the itchy sauce in your underpants?
Big_T
T
Stimpy433
Chad
Iowa
2022 Mavrick
It will be fine, my ram has the same difference and it’s been fine for the last 7 years….
Big_T
T
@Cranium please be sure to let us know what your service department says.
Snax
North America
Dunno, must have been you.
What, by wondering whether anyone had measured a few parts to isolate the issue? Oops, did it again. You must have a pretty bad rash by now!
abjbrtd
TX
Hyundai Kona, Thor Citation
I did a quick search on the broader internet and here, but didn't find anything.
My tailgate cables are uneven. The left one has a tiny bit of slack, in either position.
I looked at some videos, and it seems like others are this way as well. Is this intentional?
Check these (4) bolts, they may be "eccentric bolts"
If they are you'll be able to adjust them to remove the slack (y)
Ford Maverick Uneven tailgate cables PXL_20211014_230229145.MP~3
adawalli
Adam
2017 Ford Explorer Platinum, 2010 Toyota Prius 3
adawalli
Adam
TECHNICAL
(of a thing) not placed centrally or not having its axis or other part placed centrally.
Haha I guess my joke didnt work so well in print
Probity
Covington LA
'24 Silverado CCSB 2.7 (a Mav. Hybrid next time?)
Can you swap the cables one side to the other? See if the problem stays on the side or if it follows the cable, my guess is if it follows the cable one of them is a little shorter. I bet your service department will order a pair in for you if its the cable thats the problem.
It's not unusual at all for truck tailgates from any manufacturer. Do the sit/stand test on tailgate. Swapping cables as noted above solved the problem on 2 trucks I've owned. On another, adding a 100 lbs or so load to tailgate evened out the cable tension enough so it wasn't a problem. If you do the above and it still is a problem, return to dealer and get them to order you replacements. Just be prepared to wait for them...
Texchappy
Tony
Lubbock, TX
2008 MINI Cooper S cabrio, 2014 Lincoln Navigator
I got it but it would have been more clear if you had engaged joke font on your reply.
adawalli
Adam
Unfortunately, work prohibits me from using any fun fonts (where I am posting from). So I must remain serious at all times. Please forgive me.
SactoJohn
Sacramento
2022 Maverick Lariat 2.0EB First Edition
I just went outside and checked my truck, my cables are uneven to.
