- First Name
- Richard
- Oct 27, 2022
- Laurens county SC
- '24 Mav Lariat, '14 Prius, '83 'Stang, more...
- Engine
- 2.5L Hybrid
i stand corrected on the the trans cooler and better fan. That was something I had not noted. I knew the EB got those, the hybrid does have some cooling to spare, that's why the radiator doesn't change. His current Lariat hybrid should already have the larger spare and of course the seven pin is required when you added the brake controller. I'm not saying it's not a good value to buy it that way (as a 4k) in the first place, but if you already have a '25 AWD hybrid, it is quite capable of pulling 4k with fairly inexpensive mods compared to trading. The big one is the brake controller for safety, the others may only need be be done if your going to stress the system with large and frequent hills, high temperatures and max loads.It appears that you didn't look that close or intentionally left out what's in the 4k Tow package. Like a trans cooler, an upgraded fan a 7 pin wire connector and a conventional spare tire. At least you mentioned the brake controller and the back up assist but nothing to keep the the trans or engine from overheating.
