towing package just for extra cooling?
slashsnake
Minnesota
Tesla model 3, Kia Soul Xline
The 2022 XLT without the luxury package did not come with hitch.
Oh yes, I was talking 2025's, sorry. They now come standard with a 2k lb trailer hitch receiver and 4 pin connector on XLT and up. They don't have the Lobo details yet, but what's currently available to build, anything up from the XL has one.
Blue_Max
Orlando, FL
I can't imagine a towing package will be available with the Lobo. It is a performance model with a lowered suspension. It is not intended for utility.
Tony Pandy
Tony
2025 Lariat Hybrid, F53 Chassis Class A Motorhome, Acura TLX, '79 280ZX
The 4K Pkg. is well worth the initial cost just for the added cooling ability. I have a 25 on order really only need the FWD Hybrid (main purpose to Tow behind RV) but also wanted the 4K capacity so AWD was my final option. When I looked at occasionally towing a cargo trailer (U-Haul rental) the stock 2K capacity does not get a very large Trailer. Upcoming Move 400 miles 1 way and doing it several times with a trailer just reinforced my decision on why to order what I have.
Tbone289
It may still be worth it in 2025, even if you have to pay the extra $800 for Co-pilot 360 to get it. IMO, the advantages for the price made it a no-brainer in 2022-2024.
Frenchy
Bert
Taylorsville Utah
" FWD Hybrid (main purpose to Tow behind RV) " did you read the ugly stories about this on the this forum?
I know what the manual says but I also read the stories.
What I now believe is that flat towing is just for emergency, low speed and short distance but this not clear. Not for long distance and normal towing speeds but it seems that there are many different opinions about this.
ejouie
Evan
Newnan, GA
'23 Ford Maverick, Atlas Blue, FWD, EcoBoost, XLT
I plan to eventually upgrade my cooling setup to the larger radiator, fan and adding the transmission cooler. I have FWD, so we shall see about fitment/compatibility.
I have had stuff overheat in the past with summertime heat and traffic in the Atlanta area. I got the towing package on my 2014 FWD Enclave, and that tolerates this environment a lot better.
Tony Pandy
Tony
Yes I have researched it in depth and there are MANY Maverick Hybrid owners across many RV forums I belong to (close to 10 or 12) that are using the Maverick Hybrid as a TOAD and No Issues. Several have over 10K miles towing as a TOAD. I have experience in setting up and towing Various TOADS and know following proper procedures is paramount in success.
Frenchy
Bert
Taylorsville Utah
Ok good for you.
What is your TOAD 's name?
SLJ
Elbridge New York
2023 Maverick XLT 4K
Only negative is slightly lower highway miles due to the lower gear ratio. The plus is better resale value.
dochawk
dochawk
doc
Las Vegas
I was after better cooling too but I learned that the hybrid does not get the larger radiator
my understanding is that the hybrid starts with the larger radiator, so it doesn't get "added" with the package. Its that wrong?
I'll definitely be lariat, which already includes the 360.
If it works the same as the F-150, there are two different ones, one for several minutes for car wash and the like, and one that stays until removed for towing.
I'd go with "FROG"
DoubleXL
Rol
Labradoristan
2023 maverick XL
And as the OP said the extra cooling is worth it for me here inTexas.
I didnt get the tow package. I dont own a trailer and no intentions to get anything bigger than a snowmobile trailer.
I kind of regret it. For the exact opposite reason... id like a bigger thermal mass to keep my truck cabin warm at -30c. My truck cools off way to quick. I can watch the temp guage go down as soon as i let off the gas.
billbillw
Metro Atlanta
'23 Maverick Lariat FX4
-30C? Shouldn't you be in one of these?
Ford Maverick towing package just for extra cooling? 1000010396
slashsnake
Minnesota
I was mistaken. The Lobo comes with the 2k lb hitch standard too. I missed it earlier. Looks like the 4k isn't available though. Which makes sense.
Deleted member 38192
Guest
4K Tow Package
The 4K Tow Package (option code 53Q) is offered on the Maverick XL, XLT, and Lariat trims as a $745 option. It requires that Ford Co-Pilot 360 also be equipped, and is unavailable on front-wheel-drive (FWD) models. Content included in this package is as follows:
  • Trailer Brake Controller
  • Trailer Hitch (Class III) 2-inch Receiver w/ four-pin and seven-pin Connector
  • Transmission Oil Cooler
  • Higher Capacity Radiator (2.0L gasoline engine only)
  • Upgraded Cooling Fan
  • Conventional 17-inch Spare Tire (215/70R17)
Ford Co-Pilot 360 1.0
Speaking of Ford Co-Pilot 360 1.0 (option code 66C), this package is offered on XL and XLT trims as an optional extra that costs $795. Features bundled in this package are as follows:
  • Automatic Emergency Braking (AEB) Oncoming
  • Auto High Beams
  • Blind Spot Information System (BLIS) with Cross-Traffic Alert
  • Cross Traffic Brake Assist
  • Evasive Steering Assist
  • Lane-Keeping System
    • Lane-Keeping Alert
    • Lane-Keeping Aid
    • Driver Alert
  • Intersection Assist
  • Pre-Collision Assist with AEB
    • Pedestrian Detection
    • Forward Collision Warning
    • Dynamic Brake Support
  • Rear View Camera
  • Rear Parking Sensors
Thanku Frenchy! :like:
Guest
One thing I notice with the 4k towing package and the extra cooling capacity, now that the morning temps are dropping into the 30's, it's starting to struggle to hold it's heat up. Normal is 4 marks on the temp gauge, but on the cooler mornings (and they will get much colder as the winter comes in), it takes 4 miles or so at 55-60 to get up to temperature, then out on the interstate at 70 it drops back to three marks lite on the temp gauge. It comes back up when I pull off onto a side road, but I can already see when it gets down around zero there may be an issue. First year with the Maverick, so will see..
Sooo is there a performance difference? Hard to imagine between those temperature digits there would be much of a gap in performance? Don't know.
Hmmm think I saw on Ice Road Truckers they put a blanket over the front grill... those kind of pads they put on outdoor public maintenance water lines. But that's below zero.
