I think you mean further forward, as you're simply removing weight from the tail of the vehicle. The difference is negligible though, as the weight difference between FWD and AWD is only 168lbs, part of which is the driveshaft of which some of it is up front. Towing will add yet more weight to the tail of the vehicle, but vehicles that are neutral or tail heavy are less stable than front heavy vehicles, not more, for the same reason that a front weighted arrow will want to fly straight compared to just a balanced or worse tail heavy arrow shaft that is more likely to rotate after being thrown.I just inherently distrust the center of mass in a fwd truck towing 4K. In a car the center of mass in a fwd is further back.
I think people are forgetting that two wheels being driven rather than four wheels being driven makes no difference unless you are on the throttle.Once, I was sliding sideways on glare ice in 4WD at less than 30MPH with oncoming and trailing traffic. Truck righted itself when the right front got some dry pavement. A major adrenalin rush for sure. My heart rate was in triple digits, I think. Years of winter driving and no trailer helped. As with most incidents the problem in usually inexperience and operator error. Bad roads and FWD only with a trailer can put you in the ditch in a heartbeat.
Most people when sliding sideways are not likely to step on the gas to try and right themselves using power, and instead will let off the gas and allow the traction control system to brake the tires individually to regain stability and control.
FWD and AWD all have four tires, four brakes, and the same traction control system. They only differ in a meaningful way when you are attempting to accelerate, a maneuver rarely performed during loss of control or emergency avoidance unless you happen to hear a beat in the background with Japanese girls chanting, "I wonder if you know, how they live in Tokyo, if you seen it then you mean it, then you know you have to go. Fast and furious!!!"
