Towing a 1500lb camper trailer with hybrid?
Mazel
Dody
St.Pete Beach, FL
Maverick Hybrid Lariat
We are considering purchasing a Livin Lite Quicksilver XLP14 equipped with hydraulic surge brakes. Dry weight is 1500lb. How comfortable would you be towing with a hybrid?
Two adults + 2 kids + camping gear for weekends. I'd estimate people + cargo = ~600-700lbs.
Mazel
Dody
St.Pete Beach, FL
I have towed a regular 4 pin trailer loaded with tools and lumber locally up to about 2000 lbs gross trailer weight with no trouble for about a year at times.
I am now looking to buy a camper with electric brakes so I needed to convert to a 7 pin and get a brake controller. I have been looking at the Scamp, Helio 2 and the Pro Lite Plus S which is about 1390 lbs dry weight. Finding a light weight camper with a bathroom and inside kitchen is tough in that weight ctegoory.
I just installed the following 4 to 7 pin kit on my 22 Maverick XL hybrid.
Carseatty Universal 4 pin to 7 pin/4 pin kit. I used the flex bed 12 volt for the auxiliary connection for charging the camper battery. I have a Curt Discovery brake controller and it needs 4 wires. The 12 volt , ground and the brake stop signal wire as well as the brake output wire connection. The kit has the brake wire so that is a no brainer to run but the stop signal wire connection is a tough one. I do not want to use the flex bed power for the brake controller and the auxiliary on the seven pin. I want them separate to allow extra load safety so as not to rely on the one circuit for both.
How did you wire in your brake controller for the scamp? Does anyone have information on how I can obtain the power for the controller brake signal in the cab fuse panel area as there is no adaptor harness for the Maverick for a brake controller unit.
Would appreciate any information or insight anyone would have.
We just bought the Prolite S Plus & towed it from Adamsburg, PA to St. Pete FL! No problems! Of course the gas mileage was lower, but nothing we didn't expect.
GPSMan
Many
Looks like a good choice. But internet says you spelled it wrong. 😎
Show some photos behind the Mav!
Keep the power gauge 50% or less on long sustained hills and nothing will overheat. It can do it!
Ford Maverick Towing a 1500lb camper trailer with hybrid? B9A56DAA-6FDA-4CC5-B018-05A4318A8BC0
Timothyd
Been towing my Scamp 13ft with zero problem fulltime for a couple months now. Barely know its there (other than MPG dropping to about 25-26 mpg).
My trailer weighs about 1550 lbs when empty. But I usually have the water tank filled and a bunch of stuff in there. So probably closer to 1700 lbs.
i also cary 20 gallons of water and gas in the trunk. Plus a gfc camper on top.
I do not have extra passengers though. Just me.
It seems to have absolutely zero problems with my setup.
Good to know, I was thinking of a teardrop trailer.
Quinnman
Maverick XL Hybrid
Quinnman
Thanks for the info . We are in the process of getting a camper and nice to hear about your MPG. WE are also in Illinois.
Mazel
Dody
St.Pete Beach, FL
LOL! Yes, I got it backwards! Prolite Plus S! We kept it under 50% or under. I was nervous at first, but it towed like a dream!
Ford Maverick Towing a 1500lb camper trailer with hybrid? 6345
GPSMan
Many
This looks like a pretty optimal setup.
Maverick2112
2025 xl hybrid.
I just got a used Venture popup. It is only about 1200 to 1300 pounds. It towed fine, but I wouldn't want to go much higher than that.
Ford Maverick Towing a 1500lb camper trailer with hybrid? popup (2)
