Tire pressure when hot.
Meeka
Jay
Castlegar B.C. Canada
2024 XLT 2.0 turbo
In the morning when I check the pressure cold with the app, the rears are both 35 and the fronts both 36, like I want. But after driving a while they are all out of whack, and I can’t figure out why! 🤣🤣🤣
Ford Maverick Tire pressure when hot. IMG_0861
Meeka
Meeka
Jay
2024 XLT 2.0 turbo
They didn't teach you Boyle's Law in school up north, eh?
Ha! Just trying to lighten the mood here billbill. If there is one thing I do know is fluctuating tire pressure here in the “North”! 😉
Last Saturday morning it was 87° ambient in the garage when I aired up the tires on my Maverick.
Using my Stanley air pump / jump starter. Because of the desert heat, I purposely set the tire pressure at 34psi .
Ford Maverick Tire pressure when hot. 20250814_090148
Same day. This is the result of the truck sitting in the sun at 100° for 1 hour.
Ford Maverick Tire pressure when hot. IMG20250814130500
Same day. After about a hour on the interstate doing 72 mph.
Ford Maverick Tire pressure when hot. IMG20250816172121
Ford Maverick Tire pressure when hot. 20250814_091312
Meeka
Meeka
Jay
2024 XLT 2.0 turbo
Aired up last week in the garage.
Same afternoon one hour sitting outside.
Same day After about a hour on the road.
Well, we all know the TPMS aren’t 100 % accurate, just close enough. That why I’ve spent a few $ on an accurate gauge.
At this point, I'm pretty happy with the accuracy of mine.
I aired up in my garage 87° ambient. Using my Stanley air compressor / jump starter.
Set on 34 PSI, which is exactly what my truck showed. SEE POST #5 ☝
Even after driving for an hour. I was pleasantly surprised. Everything was equal in the parameters I expected.
Ford Maverick Tire pressure when hot. Screenshot_2025-01-24-10-22-40-08_40deb401b9ffe8e1df2f1cc5ba480b12
Ford Maverick Tire pressure when hot. 20250824_083440
Jasun
Jason
Austin, Texas
That’s totally normal - tire pressure goes up once they heat up from driving. As long as your cold pressures are set right in the morning, you’re good
d7602002
Joseph
2024 Maverick XLT
If you drive in reveres on the return trip they should go back down to the original setting.
I'll wait for the replies from those who lack the jest detector.
That makes sense. Wouldn't it also make the mileage go backwards... 😉 😂
matmondro
Mathieu
Vassar, MI
Ferris and Cameron had it figured out back in '86 😂
matmondro
Mathieu
Vassar, MI
@Meeka I'd say those pressures are fine though!
On my truck the driver's side also always gets to be 1 PSI higher than the passenger after driving and getting up to temp.
Joe Strummer
Squamish, BC
2024 Ford Maverick XLT Tremor
That's like "what happens if you play a Country & Western record backwards?" You get your truck back, you get your job back, you get your chick back...
