This article points out axles are different in hybrid mavericks-
GPSMan
Many
Try blowing it out of your chingus-
Interesting concept.
Are you referring to a Korean friend?
Or the former Emperor of China?
Ford Maverick This article points out axles are different in hybrid mavericks- 916CE9F7-A4EF-4C4F-B538-71597D33C5A7
Ford Maverick This article points out axles are different in hybrid mavericks- FE0445FC-7EE5-4CB4-BB75-9C1AC3074969
Chingus
fossil
ernie
ohio
Chingus
another misinterpretation so to speak ;)
Vaportrail
Vaportrail
Arizona
XL
Chingus
I see your research is sub par-
You better check the urban dictionary...
GPSMan
Many
Or was it because you couldn't come up with anyhing?
Ford Maverick This article points out axles are different in hybrid mavericks- 39FCD820-928D-4B95-8832-3F2E63285DA4
RedRider
Kitchener, Ontario, Canada
From my observations here, seems like CV axles go bad way too often compared to the other hybrid drive line components-
The number of Maverick owners who are doing stupid things like lifting their truck and changing the driveline angles past what the CV joints were designed for is pretty impressive. There are several good reasons why the Tremor has different halfshafts with its 1" lift. Except for people damaging the CV boots with rock hits, I'd bet that the owners who leave their vehicle unlifted have essentially no CV damage. People do not see this failure on the Escape with the same chassis and suspension components because they do not lift them. I'd like to see some numbers, and also how many of these lifted suspensions are getting warranty replacements when they should not be eligible.
fossil
ernie
ohio
Tailender
Will
Poconos
"2022 Ford Maverick all-wheel drive models utilize Dana’s Spicer AdvanTEK Ultra axle with Spicer SmartConnect disconnecting all-wheel-drive (AWD) technology, which was tweaked to work in the front-wheel drive-based pickup."
Would this mean for the hybrid also?
Don't mean to get in the middle of the battle. Just asking.
Vaportrail
Vaportrail
Arizona
XL
No battle here, just feeding a couple of trolls this afternoon...
Bob The Builder
Butch
Vermont
No. The torque is mild and very carefully controlled. And yes, I've measured it. At least monitored what a computer says the torque is. I didn't put my hands on it.
Ahhh, well that does make sense does it not? Thanx!! At any rate, no lift or oversize tires for my EgoBoost going forward as I have no logical reason for either one so not going to sweat it.
MaveRichard
Rich
MI
2023 Ford Maverick XLT Hybrid
The way that the article is written is not very clear. To me, it seems to indicate that Ford is manufacturing the HF45 in house instead of the CV axle shafts.
With that said, I can get mine to shudder a little bit in high torque scenarios. Under 35mph, over 50% power requested. I will monitor and probably have them replaced as I get closer to warranty expiration - waiting mostly in case they update the design.
Knowing the design of the front suspension, I can't imagine wanting to put the CV axles in a worse position mechanically by lifting it. To each their own I suppose.
Either way, it would be interesting to find out if the hybrid does indeed use different CV axles. I know we have a few members here that work in dealerships. The parts counter at my local dealer would share this part # information with me if I asked too...
TheSEARCH
ford
Well for one thing i think the axles on a hybrid are subject to a lot more wear. As they do the braking a lot too besides acceleration. That extra wear and tear might make you think the axles are a little tougher? I have no idea if they are or not. If not maybe they will wear out faster and become an issue down the line.
Not a huge job I can do it myself. Rock auto has escape hybrid axle at about 160 bucks per side,. not huge issue.,
Vaportrail
Vaportrail
Arizona
XL
I searched for "Ford Maverick 2.5 axle assembly" and actually found what I was looking for...
For a much lower price than the EB variety???
Ford Maverick This article points out axles are different in hybrid mavericks- Screenshot_20231004-132407
Ford Maverick This article points out axles are different in hybrid mavericks- Screenshot_20231004-132355
Vaportrail
Vaportrail
Arizona
XL
I cut the wheel both ways and took a peek at my front end-
At 11k all 4 of my boots are dry...
I noticed a nice sticker on the shaft
Ford Maverick This article points out axles are different in hybrid mavericks- PXL_20231004_210348071
NoVaJimmy
KCMO
Lexus GX 460
Seemed to me the subject was Dana axles and differentials being used in several Ford models EXCEPT for hybrids, and also mentioned the electric motor-
If Ford isn't making the hybrid axles in house, then I wonder who's manufacturing what seems to be the weakest link in the hybrid drive line???
That's not what this article means. They brought the electric motors of the drivetrain in house. The axles have the hyundai logo stamped on them, that's hardly in house. A Dana solid axle is a far cry from anything found on the Maverick anyway...
NoVaJimmy
KCMO
Lexus GX 460
That's a parts locator sticker, look closer on the boots and clamps for where it REALLY comes from
