This article points out axles are different in hybrid mavericks-
GPSMan
Many
I cut the wheel both ways and took a peek at my front end-
At 11k all 4 of my boots are dry...
I noticed a nice sticker on the shaft
Did you blow your shaft out of your chingus? Is that why you need a new one?
If your front end is dry maybe you need a lube job? How's your rear end?
Vaportrail
Vaportrail
Arizona
XL
What is the weakest link in the hybrid?
And how do YOU know?
Show proof. Give documentation please.
Thank you.
[/QUOT
Somehow I knew you couldn't move along-
Even though you obviously know little to nothing about actual mechanics...
It's ok to be obsessed with my shaft, but could you please stop being such a pathetic troll???
billbillw
Metro Atlanta
'23 Maverick Lariat FX4
The Dana components in the Maverick only apply to the AWD models and it is the rear axle/differential they are talking about. The front CV axles are not Dana on any of the Mavericks.
23MAVLariatAWD
VA
RECEIVED '23 Hybrid Lariat Mav Oxford White BAP
So what do you all think about putting 235 ,60,18 tires on a hybrid (truck came w the 225, 18)? Would that really cause more wear on the axles? Thx 4 any insight-
TheSEARCH
Dan
ford
I wouldn't think bigger wheel/tires would do much. BUT lifting truck if needed to get them to fit would. If no lift needed I wouldn't worry about it. Thats my 2 cents.
GPSMan
Many
Some guy on here thinks it will blow out your chingus. Do you want to risk it?
23MAVLariatAWD
VA
Lol 😆 good1....cross climate 2 are my next set of tires...235 18 60 ...highly rated for rain & snow in consreports as long as the 235 don't mess up the axles...
Vaportrail
Vaportrail
Arizona
XL
Yeah, you gotta be careful deciding who's advice is worth listening to-
My advice???
Beware of know it all clowns that think a tailgate net is a good idea!!!
GPSMan
Many
Tailgate net: I see no use.
Unless maybe your tailgate got stolen and a replacement is on infinite backorder. Then it's one increment above useless.
But that's me.
But off topic. I'm sorry Vapor brought it up.
Vaportrail
Vaportrail
Arizona
XL
But that's me.
Good news-
You can edit your avatar picture...
You should try it!!!
GPSMan
Many
Good news-
Knew that long ago. Glad you finally figured it out.
Why not add something truck related to yours now?
NoVaJimmy
KCMO
Lexus GX 460
Dana makes the RDU which is a rear differential unit, which is not an axle. Yes it is a Dana supplied part but OP is mistaken in designating it as an axle.
fossil
ernie
ohio
Wasn't @fossil the one who thought hybrid axles are from Dana???
If Dana made the hybrid axles, I doubt we'd be seeing so many premature failures-
yes I expected they were Dana. You were the one who thought the axles were Ford built and the electric motor was just a mere mention in the article.
