Thinking of Making my own 2.3
Vtec87pr1
Antonio
Virginia
youtube.com
2022 XL Ford Maverick
As i posted before on my built page i did not seem to find any real differences between the engine block between the 2.3 and the 2.0 . other than the crank rods and pistons.
i might waste my money on this but i think its worth trying. Anyone thinking of doing the same i can post stuff of the specs here later on when i get all the information write up.
Vtec87pr1
Vtec87pr1
Antonio
Virginia
youtube.com
heres some example i got to buy a crankshaft for 2.3 Ford Explorer and as you can see it says it will fit the following vehicles.
Ford Maverick Thinking of Making my own 2.3 1699143205321
the only fear i would had if one of the counter weight might might hit the block area but i guess im going to have to take the risk. btw im trying to make a stoker kit lol .
jewc75
Vtec87pr1
Vtec87pr1
Antonio
Virginia
youtube.com
rallyshark
Donny
GA
2023 Maverick Hybrid
Is it still true people prefer to build the 2.0 over the 2.3, because the open deck on the 2.3 eats head gaskets? I haven't been following Ford's ecoboost stuff as much as I used too, but I figure building a 2.0 is the better way to go from what I remember. I do understand you're wanting to use an actual 2.0 block, btw.
jewc75
The head gasket issues were the head gasket itself, they were junk. You hardly ever see cracked 2.3 or 2.0 blocks. Some people will have Darton sleeves installed for high hp stuff. Mountune does darton sleeves but they are pushing almost 700 hp. Every ecoboost mustang i know that has done head studs and aftermarket head gasket are pushing 400+
Vtec87pr1
Vtec87pr1
Antonio
Virginia
youtube.com
The head gasket issues were the head gasket itself, they were junk. You hardly ever see cracked 2.3 or 2.0 blocks. Some people will have Darton sleeves installed for high hp stuff. Mountune does darton sleeves but they are psuhing almost 700 hp. Every ecoboost mustang i know that has done head studs and aftermarket head gasket are pushing 400+
I seen some cracked blocks on the 2.0 and 2.3 its mostly between 2 and 3 cylinder
Tim d
Alpena
Ram
Personally,I think it would be a waste of time,effort and money to achieve little,and maybe lose driveability and warranty. But,I've done some wasteful things in my life sooo. Good luck!
Vtec87pr1
Vtec87pr1
Antonio
Virginia
youtube.com
Your right. But for me its too late lol 😆. I bought a short block already.
The Cyber Orange Guy.
Devu
Caribean
Maverick cyber orange
It finally got here alredy started tear down.
Ok, let me get the popcorn, this gonna get interesting.
I seen you're a pretty handy person, let's hope your project get done as easy posible. you guys really are paving the roads.
Vtec87pr1
Vtec87pr1
Antonio
Virginia
youtube.com
Well we will see what happens but this its going to take a while
do you have a tune and if so which are you using?
I think it might run with the swap but I'm pretty confident it will need a new tune. are you keeping everything else stock for now just swapping the short block?
