The last straw? (Vehicle down for 3+ weeks, with no end in sight.)
JimParker256
Cedar Park, TX
Vehicle: 2023 Maverick Hybrid Lariat, purchased from Covert Ford in Austin, TX.
I went on a short trip (Cedar Park, TX to Sequin, TX - about 80 miles) in my Maverick, and stopped for lunch before going to my appointment. I finished lunch and was driving the approximately 1.5 miles to the appointment. About halfway there, I stopped for at red light at an intersection of a major road and an interstate highway. Just as I pulled to a stop, the Sync system went blank, followed by the main driver's display, then almost immediately both came back on, but with every single warning light illuminated, and pop-up messages from all of those systems coming up so fast that I lost track of how many messages I got. The gas engine, of course, was shut off (as always at a stop), but the transmission was now in "Park" (I didn't touch the shifter) and the parking brake was ON. I could not change into Neutral, nor release the parking brake. Turning the vehicle off (push-button) and back on did nothing. So I was just stuck in the middle of the intersection, with the noon "rush" flowing around me (lots of angry looks, honks, and raised middle fingers directed at me). I tried everything I could think of (including searching the Maverick Truck Club) for similar scenarios and how to resolve it) with no success.
I have a Ford extended warranty, so I called them to tow me to a dealership. But the local dealership said they had no one in their service department qualified to work on hybrid vehicles, and that I would have to have it towed to either San Antonio or Austin to get it worked on. Since my "home" dealer is in Austin, I decided to have it towed there. However, Ford's towing service will only pay for it to be towed to the nearest dealer, so I had to pay almost $300 to get it towed to Austin.
This post is already going to be long, so to shorten it somewhat, my service advisor told me the only thing wrong was that the 12V battery was absolutely dead - zero volts - and that it would not accept a charge. Something must have broken inside the disabled the entire battery. They replaced it under warranty, but the detailed explanation I got from the service manager and technician scared the hell out of me! If the 12V battery fails like this, the computer shuts down the engine (and electric power as well) and puts the transmission into Park, and applies the parking brake. Until the computer sees a normal 12V signal again, it will NOT allow the vehicle to be shifted out of Park, nor allow the parking brake to release. This seems absolutely crazy to me, given that the high-voltage battery was absolutely fine, and we all know that the HVB is what recharges the 12V battery, whose only purpose is the power the computer when the hybrid system is shut down Why the hell would Ford engineer the system such that a 12V battery (an accessory at best) would force a critical shutdown - as though it were a nuclear reactor performing an emergency shutdown? It's not only ridiculous, it's downright dangerous!
The truly scary part is that if the battery failure had occurred 2 miles prior or 2 miles after it did, I would have been on an Interstate highway, going 75 mph (speed limit in this area) when the computer decided to put the vehicle into Park and apply the parking brake. Whether it would have done so at 75 mph, I have no idea (nor did the tech), but even if it had just shut down the engine and hybrid power system and had me coast to a stop, then shifted to Park and applied the parking brake, I would have been in some seriously fast traffic with an immovable vehicle. What are the odds I might have been killed in the almost inevitable rear-end collision that would follow?
This seems like a MAJOR design flaw. My wife won't even set foot in the Maverick any longer, and doesn't want me to drive it either. We both believe this is a significant hazard - especially given the track record of the 12V battery failures that have been a chronic issue in the Maverick Hybrid, as you can definitely see from these forums... So I' will no longer drive on the freeway in my Maverick, nor take it on long trips, since it has stranded me three times now. I'm starting to investigate the Lemon Law in Texas...
To make matters even worse, I have also experienced three separate occurrences of "multiple sensor" warnings:
  • Pre-Collision Assist not Availble
  • Powertrain Malfunction / Reduced Power
  • Blind Spot Detection with Cross traffic
  • High-Voltage Battery Warning (detailed message says stop as soon as possible and contact authorized dealer)
  • Service Engine Soon Warning
The first time, the dealership (280 miles from home) told me the Engine Control Module needed to have the software reloaded. Doing this seemed to return the vehicle to service. The out-of-town dealership put me at the head of the queue since I was on a trip, and got me going within a couple of hours. I was extremely grateful for their quick response.
The second time I got this rash of messages, I tried, but I could not clear the problem by shutting down and restarting. This time, the dealer reported they cleared the errors, but could find nothing wrong afterward, and the vehicle performed normally for them with no further errors. This was also at an out of town dealership. I mentioned it to my "local" dealer when I went in for an oil change, but there were no errors in the system for them to go on.
The third time it happened, I was here in town, and got the "High Voltage Warning" that basically means "park the vehicle." So I again had it towed to Covert Ford. It took two days for them to get it into the shop to actually work on it. After almost a full day of diagnostics, their tech found a "damaged" connector plug in the wiring harness where the ECM connects (apparently under the hood, in one of the back corners). When he jiggled that connector, the system threw all kinds of warning messages, including the ones above. They attempted to order a new connector, but apparently they aren't in Ford's ordering system - you can only order the complete engine wiring harness. My service advisor (good guy) told me he asked why the didn't just get a new connector from somewhere like Granger, cut the existing wires, and connect the new one... Seems the wires are short enough that if they cut them, the connector will no longer reach the plug where it needs to connect.
Two days later: Bad news, no wiring harnesses available anywhere in Ford's system, and they are back-ordered, but that Ford had agreed to upgrade the order to "Emergency - vehicle not on road" status, which should give us the highest priority when the harness became available... Two days later, I was contacted by someone in Customer Service at FoMoCo, telling me she would be following up with me, keeping me updated on all the effort FoMoCo was putting toward getting my vehicle repaired to my satisfaction, and promising the would be my primary point of contact until my vehicle was repaired and back in my hands. But basically, she told me nothing the service advisor had not already told me... Fast forward several more days, and today I was contacted by a different person at Ford Customer Service, letting me know that she had tried to contact the dealership, but wasn't able to get anyone, so she had no "dealer update" for me, but that my back-ordered part was showing "pending upgrade to emergency status". I asked why it wasn't already ON emergency status, and she said "well, they don't have any in stock, so they can't make it an emergency status until they do." (Seems to kind of defeat the purpose of allowing back-orders, doesn't it?) In any case, she was totally not helpful, except to ask if the dealership had given me a loaner car (they had not. - none available when I took it in).
So after I got off the phone with her, I immediately called the dealership (which she said she could not reach "anyone" in the service department, and would not try again until after the weekend - this at roughly 2PM on Friday). The phone was answered immediately, and I was able to get my service coordinator on the phone in less than 1 minute. (So she was full of you-know-what...) I expressed my frustration at being without my truck for 3+ weeks, and asked if there was any possibility of getting a loaner vehicle. He escalated the case to his management, who escalated it to the sales team, and got approval for a loaner. I just got back home from picking up a 2024 F-150 that will be my loaner until my truck is fixed. My thanks to Covert Ford (Austin, TX) and William Heinrich (service coordinator - who had been great to work with every time I've been in the shop).
When I first took delivery of the Maverick (July, 2023), the entire sound system was non-functional. All the features "worked" other than the fact that there was no sound at all from the Sync system (so no sound through Apple Car Play, either). The dealership diagnosed the issue within a couple of hours (a bad hardware module in the Sync system), and told me it was back-ordered with no estimate on when it would be delivered. They offered me the choice of leaving the vehicle with them until the repair part came in (with a loaner in the meantime), or just go ahead and keep the truck until the part came in, at which time they would contact me an schedule a repair. Since I had only JUST picked up (and paid for) the Maverick, I elected to keep it until the part came in... Glad I did, because the part didn't come in until late December, 2023 - that's 6 1/2 months after it was ordered! Because it came in just as the holidays hit, they gave me a Mach-E loaner for Christmas holidays. When I got back from my son's house after Christmas, my truck was finally ready, and I got to hear the sound system for the first time. So again, I feel like Covert Ford did their best to accommodate me, but the FoMoCo parts inventory system let both of us down pretty badly.
And Ford, you've got some serious 'spraining to do... Either A) Ford has the worst spare parts inventory management of any motor vehicle company I've ever dealt with, or B) there has been a massive run on replacement engine wiring harnesses. To me, it is totally unacceptable for a truck to be "down for parts" for more than three weeks (this time) because there are no repair parts available in the system. In any case, the Maverick Hybrid that I absolutely loved at first has proven to be completely unreliable.
At this point, I cannot recommend to anyone that they purchase a Maverick Hybrid.
Beekeo
Massachusetts
2022 Ford Maverick, 2018 Ford Escape
That sucks, I’m sorry to hear it
it does sound like Covert Ford has good people working there - have they discussed different vehicles you might trade for?
JimParker256
JimParker256
Cedar Park, TX
No, thus far I've only been talking to the service folks. Honestly, an F-150 won't even come close to fitting in my garage, and I really like having a pickup to haul lumber (woodworking is my hobby). For years, I put off buying anything, because there was nothing on the market the met my needs. The Maverick form factor is absolutely perfect for me, and I love the truck - but I don't trust it - at all... And that's just such a shame.
1929
Lake Michigan
Ford Maverick XLT Hybrid
Sorry to hear of your reliability problems. Wish you luck to resolving them.
This is unacceptable. For over 20 years Ford has sold hybrid vehicles.
I would contact Ford and ask them to pay for the towing.
bgn
WA
See if you can lemon law it. Ford customer service is absolutely abysmal.
I went back and forth with them for months after a botched side airbag recall. They simply do not care about you or your safety.
Absolutely the OP "JimParker256" should look into Texas lemon law.
https://www.txdmv.gov/motorists/consumer-protection/lemon-law#:~:text=How does the Lemon Law,under the manufacturer's original warranty.
Ford Maverick The last straw? (Vehicle down for 3+ weeks, with no end in sight.) 20240928_090629
The real sucky part, is when you find a vehicle that absolutely suits your needs and purposes. And it turns out to be a lemon. I can understand how that would sour you on the entire brand.
No pun intended.
Good luck
  • Like
Reactions: bgn
JimParker256
JimParker256
Cedar Park, TX
Thanks for the link. It says pretty much what I remember it saying... You basically have to have the same issue 3 times (with no successful repair). The first issue was allegedly repaired (we'll see), and the second one only happened (officially) once. Is it bad to "hope" I actually have the issue a fourth time so that I can prove it wasn't "successfully repaired"? :curse:
BlueMav43
Roger
NE FLA
2023 Ridgeline RTLE, 2018 Tahoe LS
Wow, Sorry to hear of your issues. You have certainly been patient.
Get rid of that one.
I let mine go just for a few irritating rattles, guess I got out easy.
Bob zimmerman
Northern <MN
25’ Maverick XLT hybrid AWD
You are obviously very pissed and wrote a pretty long post with a lot of adjectives.
Two items that stick out to me.
When your vehicle died and then was stuck in park, my first thought was that you had a bad battery connection, even before I read about your battery. My Prius will not do a damn thing without the battery connected either. How can it. It needs the 12 volt battery to start the car. The hybrid battery is not part of that system. Once the vehicle is on, the alternator puts voltage to the battery so even if this ‘happened on the freeway’ the vehicle will run since alternator is charging that battery (even if it’s dead).
No part available is pretty common now. I have a Honda CRV that has had a recall on it forever, dealer just says ‘no parts available’.
Tech Tye
Ken
Kentucky
2023 Maverick
WOW!, 3 weeks down. I would take that over mine is down for 4 MONTHS!. I’m still waiting on a wire harness that controls the transmission. Harness is on emergency back order since July , may ship November 10th. Pins corroded in the 40 pin connector under the fender.
fossil
ernie
ohio
ronlennon
Ron
Wyandotte, OK
2023 Maverick Lariat Hybrid & 2018 Honda Civic Sport Touring Hatch back
I also have a Honda Civic 2018 with recall on fuel pump and dealership says there are no parts yet to replace. I first called them in July.
SLingbarT
Saint John Indiana
2023 Hybrid Lariat Lux in Cactus Gray
Watch this Video on what this Mech found:
