Billzilla15
Ohio
22 Maverick Lariat
posted this on Facebook but wanted to join here to post it and try to put my thoughts down into somewhat of a install guide for everyone since that has been requested about a thousand times. i installed the sync4 apim and screen from a escape in the maverick the other day. this will be a parts and ROUGH install guide but it will point you all in the right direction, PROGRAMING is up to you. every truck is different. this requires a decent amount of forscan knowledge. and my install is on a lariat that already has the sync 3 system. if you have a xl or xlt there is a thread here on installing a sync4 apim to that truck and you can adapt the two to make it work for you if you want to
Ford Maverick Sync4 APIM and 13.2" Screen Installation Guide (Lariat Models) PXL_20240718_190146709
Onto the Install
You Will Need
1. Sync 4 Apim (the sync 4 apim comes in 4 flavors, 8in screen and 12+ screen, with or without navigation. you will obviously need the 12+, the 12+ is identifiable by the 6 pin screen connection the others are only 4 pin)
2. 23+ escape Screen Part No NX7T18B955LE
3. Screen to Apim Plug ML3Z14D202B
4. Power Plug 6U2Z14S411JB
5. Sync 3 pass though harness (i got one of the sync 3 camera adapter plugs on amazon)
i got some stuff from for others on ebay and have about 600 wrapped up in it all
Ford Maverick Sync4 APIM and 13.2" Screen Installation Guide (Lariat Models) 41JhKv0JLJL._AC_UF1000,1000_QL80_
the pass though plug needs modified before install, you need to Completely remove pins 41/42 AND pins 53/54. you can use the removed pins to replace the rca plug and connect the camera back to passing though
Ford Maverick Sync4 APIM and 13.2" Screen Installation Guide (Lariat Models) C2383A
the power plug 6U2Z14S411JB will need pin 1 tapped into pin one of the pass though harness and pin 4 tapped into pin 37. this will provide power and ground to the additional connector of the screen.
Ford Maverick Sync4 APIM and 13.2" Screen Installation Guide (Lariat Models) Untitled-1
Ford Maverick Sync4 APIM and 13.2" Screen Installation Guide (Lariat Models) PXL_20240717_202328395
on to the install.
the apim is located behind the hvac controls and the radio module. once the radio module is out there is a bracket holding the apim in with 3 7mm, remove that and swap the apim out for the 4. run your new screen plugs from the apim up to the screen.
Ford Maverick Sync4 APIM and 13.2" Screen Installation Guide (Lariat Models) PXL_20240718_183428776
the screen install is custom, i need to print a bracket for the mount to get rid of my snap-on spacer lol. i used one of the holes to mount the screen and its solid enough but will need to refining
Ford Maverick Sync4 APIM and 13.2" Screen Installation Guide (Lariat Models) PXL_20240718_190208158
the tray behind the new screen will need to be modified because the new mount is so high up now. i used a heat gun to massage the plastics out of the way.
plug everything in. the pass though harness is just that a pass though and it allows you to not modify your existing harness in the car. there are several plugs on the sync 4 apim that are not used so dont freak out about that. reinstall everything and you'll be ready for programing
Ford Maverick Sync4 APIM and 13.2" Screen Installation Guide (Lariat Models) PXL_20240718_173936752
Ford Maverick Sync4 APIM and 13.2" Screen Installation Guide (Lariat Models) PXL_20240718_190001064
i will try to respond here when i can but Facebook in the maverick groups is probable your best bet. hopefully this is helpful yo you guys
****Update**** if you are using the 13.2 in escape screen make sure you get a apim from the same model year 23 or newer. We have found that the older ones don't have the firmware for the screen installed because the screen wasn't introduced till 23. So for a example a 21 f150 apim will not display properly on the 23 escape screen
fossil
ernie
ohio
only one camera input?
nice work. do you have normal, full functionality from FordPass?
Billzilla15
Billzilla15
Ohio
22 Maverick Lariat
I do. Well it shows remaining miles and the lock unlock remote start work. So good enough for me
TheShark
Sweet, nice job.
This is awesome. I'd love to do this but I know I'd break something.
I do not have time or interest in the tweaking. I couldn't dump 20-40+ hours into something like this, especially in a vehicle I need daily. as long as the truck is running, I guess I could live without the infotainment a few days, but I wouldn't want to.
it's damn cool but the cost - difficulty / time - benefit triangle doesn't appeal to me. dealerships aren't going to want to trade for a truck modified like this, and it's a crapshoot whether a private buyer thinks it's awesome (probably) or a risk (maybe).
Billzilla15
Billzilla15
Ohio
22 Maverick Lariat
Nothing is permanently modified so back to stock whenever it's needed
ilikebike
2024 Ford Maverick Lariat Hybrid HPR w/ BAP
Then why post at all?
Dmat
Baton Rouge
MAVERICK
So from my understanding, Its not necessarily screen size that matters but pixels. I'd wonder if we could swap the screen to a different one and attach the electronics to it. I wonder how big the circuit board is inside the housing.
I was replying to the person who stated they would like to do it but were afraid of breaking something. and the purpose of your post is? ;)
