Ranch
Sacramento CA
2023 Marverick FX4 4K
I searched but couldn't find any mention of "fluid" in this thread, so I wonder if anyone has suggested that a service brake system leak like a loose bleeder could have allowed the DOT4 reservoir to run dry. This could explain OP's situation. Maybe... Although I would have expected a warning light and some behavioral issues between "normal" and "total failure".
If the fluid reservoir ran dry why did the brakes begin to work again after the crash?
Note that brake failure is not SUDDEN until it happens.
JPatterson
Audi S5
I would be very surprised if if the Maverick doesn’t have a low brake fluid sensor and warning that occurs long before the brake fluid reservoir runs dry. On most vehicles a failed master cylinder can allow the pedal to travel further than normal but I think most all vehicles have dual master cylinder design that keeps some braking even if a master cylinder or caliper seal or hose were to fail.
Wondering, Does the regenerative braking system on the hybrid eliminate the mechanical connection between the brake pedal and the the hydraulics ( master cylinder)?
the regenerative system is applying resistance via the 2 electric motors which are generators when they are spun in reverse.
it doesn't use the hydraulic fluid and caliper at all.
MetalsGeek
Rough
Torrance, CA 90503
Down to just the Mav
...but regenerative braking only works when you're moving fast enough for the generator to generate useful power. Somewhere between 3 and 5 MPH, the brake system transitions to normal friction braking to complete a stop. This was the source of many complaints for the '22 MY hybrids, because the friction braking came on too abruptly at that point. Every service brake system should have a direct hydraulic connection from the pedal to the calipers as a last resort, in case normal functionality fails. It's my understanding that the Maverick hybrid EBB (Electric Brake Booster) includes this in its design along with the ABS controller. However, details of this unit are hard to get because it's not considered a serviceable part.
MetalsGeek
Rough
Torrance, CA 90503
Posts #3, 4, 11, 19 and 42
Ahh...I understand your profile pic. 😂
I deserved that. 🤪 I can only say that I used the Search function looking for the key word "fluid" in all of OP's posts this month and it came up empty. Silly me...
JPatterson
Audi S5
Yes, I understand. What I do not fully understand is the handoff between regenerative and hydraulic braking. I assume that there is a device which senses brake pedal pressure and initially uses regenerative but allows hydraulic braking when the pedal is pressed harder. Some describe “brake by wire.” but surely there is a mechanical connection that allows one to apply brakes even if all electronic control fails.
Sure, there has to be somebody in the crowd with common sense and states the obvious. 🤣🤣🤣
Divine intervention??? 🙏
Phimosis
Larry
Santa Clarita, CA
But still no follow up from OP?
Nope. Took truck to shop, no error codes, everything tested out normal. No leaks, no low fluid levels. Brakes worked fine.
No reason to make a follow up post since the visit to the dealer didn’t add any new information. 😂🤣😝
OldNavyGuy
G
3575X
Ford Explorer, 2024 Maverick Lariat
Was this a hybrid?
We had a similar experience with a hybrid 14 yrs ago. It turned out to be a bad wiring harness. Fortunately no one was hurt, or damage done.
