- First Name
- Mike
- May 3, 2024
- KC Metro area
- 2005 Toyota RAV4, 2024 XLT Hybrid
- Engine
- 2.5L Hybrid
Easily could have had the scenario described prior then with HVB full (EV coach shows that, not the power meter).
But into the pads means full regen happening then.
That means the ICE is going to be used for air braking.
But if ICE was running for heat or required for power used, the generator motor is making changes from gearing needed for required power, to instantly gearing needed to spin the ICE at RPM needed to waste the electrical.
That can be very different RPM, actually opposite direction RPM.
Perfect storm you might say.
The fact it stayed shuddering that way down to 10 mph is different - once GM reverses RPM direction that's done. Once ICE is spinning with no fuel that's done.
This might involve the damper between ICE and eCVT then.
Noticed any shudders when idling in P or D, even N actually?
Might be felt too on accelerations with ICE at just the right power level that allows the vibrations thru.
Next time it happens on coast down - switch to N and be ready for full brake pad engagement with no regen.
