Butterscotch
2025 Eruption Green Lariat
Finally got to this project:
VAIR 12v 23amp 2CFM (enough to seat a tubeless Mtb tire)
Hard mounted into the bed cubby
Wired directly to the 12v battery under the rear seat in the hybrid. I installed a 30amp fuse inline to the compressor. Routed the wiring along the factory harness above the fender well, and thru one of the body vents into the backseat.
Nice and clean fits like a glove!
You need to put a wire grommet on the outbound wire hole. Come spring you are going to have a wasp nest the size of the compressor.
Joaquin F
Joaquin
LA
2022 Mav Hybrid XL
Nice install love it! Thanks for the outline
Heyspike
Hudson Valley NY
www.johnryan.us
C5 - Fairway Green, SIlverado
Boy that's a great pace to mount that. I need a small tank and place to mount it for my airhorn too.
protijy
Scott
Bentonville, AR
Ford Maverick Stealth onboard air compressor install in bed. IMG_8476
I am contemplating adding a 1 gallon tank underneath the cubby inside the rear fender. This is looking up at the bottom of the cubby with a plastic panel removed under the truck. That sheet metal would be a perfect spot to mount a reservoir, strong enough to hold it also hidden and out of the way.
sprubs
New England
Nunya
what would you put in there?
vertigo12369
MK7 GTI
I would say both for that reason and to protect the wires.
Butyl tape / gum will work as a quick DIY. Mounting holes will leak too. Not sure how you fused it...grab some tesa 51026 / 51036 to protect the wires from the sharp edges.
eighty4south
San Diego, CA
2024 Ford Maverick XLT, FX4, 4K Tow, Atlas Blue
Mavtremor24
Tony
Ohio
2024 maverick tremor 2024 space ford explorer timberline 2000 black svt contour
dumbcomputers
The Earth
2025 Maverick Lariat Hybrid
I keep a rigid battery inflator under my back seat ,works great!!
That looks perfect. The only reason why I went with one I have is that I needed 120 max PSI support at the time. I don't need it now and probably would get something smaller but I already have this one..haha.
