Some form of automatic braking is annoying me
My truck is admittedly a 2023, but that doesn't sound like pre-collision to me. I adjusted the sensitivity on mine to the least-intrusive setting, but occasionally still get warnings. No one in the truck cab (or within a few car lengths lol) would be able to overlook that. It's a lot of flashing and beeping.
I have never had it apply the brakes. The threshold for that is so high that very few have experienced it.
If you don't start to brake and you have distance required to x car lengths then it will start to brake to Maintain that distance. Also if someone is in your blind spot steering in that direction will be restricted. Max braking can occur stopping the maverick about 30" from contact. Someone cut across my lane from passing to make a right turn but he had to stop with 1/2 his vehicle in my lane.
Busa789
Busa789
Dennis
Iowa
2025 Lariat
That fits with my expectations, and I haven't gotten any warnings.
Busa789
Busa789
Dennis
Iowa
2025 Lariat
Makes sense, but the distance between us is significantly greater than the following distance ACC allows, and is set for in my case.
Clarkdonbran
It is a 2023 hybrid and gets 35 MPG (calculated). It is my wife's car and she loves it. When we started looking she thought she wanted a Subaru Outback. We test drove one and then rented one for a couple of weeks. We would drive it to test drive other SUVs and she decided the Santa Fe was best. The thing she likes most about it is the 360 degree camera and encouraged me to get the Lariat trim Maverick because it had the 360. We have had zero problems or recalls with the Santa Fe..
Good to hear! Thanks for responding. I have a feeling the Santa Fe will be our choice.
aknolobo
Gulf of America
F150
Dennis, @Busa789
Pre collision assist is what you probably experienced.
I have mine set at High the most sensitive setting. I want plenty of notice.
It has never activated the brakes.
According to the 2025 👇🏻 manual you can turn it off. Temporarily.
At the bottom of the page it also notes that it will reactivate when you restart your truck. In other words it's not something that you can permanently disable.
The brake lights do illuminate
When the truck activates collision avoidance and applies the brakes.
That's not true. You can turn collision warning/ assist permanently off even after you restart the vehicle.
Most manufacturers like Toyota, Honda, Nissan, Hyundai do not allow permanent off.
I don't buy vehicles that cannot turn off collision warning/ assist permanently off.
Please show us how to permanently turn off the collision warning assist
Ryom
PA
2025 Maverick Lariat 4K BAP Eruption Green
I've not had any of the nannys overly bother me after adjusting the settings to taste. There is an occasional hiccup but it's immediately understandable what happened usually.
However, I'm going to be honest... every time I ride with someone who complains about their collision warnings, lane assist, or other nannys going off all the time, I understood why within a few minutes. And I usually don't volunteer as a passenger twice.
pigsareus
Farmington Hills, Michigan
Maverick XL Hybrid
Thanks guys. Yeah, I looked at pre-collision settings and mine is in the middle setting. What gets me is the other vehicle is considerably ahead, not a risk, and maybe not even going slower. I don't see any notification on the dash.
My 2022 Camry had pre-collision assist, and it never did this. It only activated 3-4 times in 60k miles and they were sketchy situations where I understand the application.
it isn't the pre collision that's doing it - when the pre-c is triggered you get a big old rectangular red box on your dash and a lot of beeping - you didn't mention that in your post so that's not it. I've had my pre-c fire up 4 or 5 times over a few years, it sort of over-reacts but it for sure isn't firing off for no reason at all.
Busa789
Busa789
Dennis
Iowa
2025 Lariat
Yeah, that's what I was thinking would be the case. I mentioned I didn't see or hear any warning on the dash. It would seem adaptive cruise shouldn't be doing it since it is well beyond the following distance I set. That's why I said "some form" of automatic braking ... not sure what it is.
It has to brake before you get to the following distance. Will brake at maybe , twice the set distance if the relative speed difference is 20-30 mph faster. It will match your speed to the other vehicle's speed at the set distance.
Busa789
Busa789
Dennis
Iowa
2025 Lariat
During normal operation of the adaptive cruse, when someone is and has been directly in front of me, it gets closer then brakes. It seems to be working properly. When someone is merging, it seems to be a greater distance, the truck brakes harshly for a moment, then often resumes to the set speed. It could well be the adaptive cruise doing it, but it doesn't seem appropriate. One other thing is that it has occurred when using regular cruise also.
Cycopath
Tucker
FL
2026 Maverick hybrid AWD
2025 Lariat Hybrid. Often when another vehicle is merging into the lane in front of me, and even once when I was the one merging, my Maverick applied some form of braking automatically. I even had it occur when someone turned from a side street onto the road in the same direction as me and very briefly crossed into my lane.
The vehicles are almost always well beyond the following distance I have set in the dynamic cruise control. I have not seen any warning on the dash, and it seems unlikely I miss it every time. I'm not sure it is cruise control related, but the situations it occurs I am typically using cruise. There really is no reason for the braking. I'm not even sure the vehicles are going slower than me when merging.
Any ideas what is going on? I've learned to live with most of the nannies, but this one I don't think I will not be annoyed by. Honestly it doesn't even seem safe if there are people behind me.
It's definitely the adaptive cruise. Pre collision assist will make more noise than an annoyed R2-D2 before it takes action.
MavStangVa
Here, There, and Everywhere
2024 LARIAT AWD
Just a wild idea but did you look to see if someone backed into the Adaptive cruise sensor in the grill? Maybe it's moved a bit or dented causing a misread.
MaverickDragon
Grand Canyon, AZ
FORD !
Dammit that’s enough !
Give us a way to disable all this nanny crap the lawyers made you stick us with !
I’ve nearly been rear ended twice when that bullshit applies my brakes for no reason.
I’ve got good driving skills, I don’t need it !
You need to expand your list of automotive companies to include all of them, and the reason these features exist is due to federal automotive safety requirements.
MaverickDragon
Grand Canyon, AZ
That seems odd, and braking for a merging car when you use CC rather than ACC sounds like it's a sensitivity issue or error with automatic braking rather than the cruise itself.
Have you looked at the forward collision brake settings?
