Shimmy/Wobble
90south
Missouri
2022 Maverick Lariat AWD
I have a 2022 Lariat AWD 2.0 EcoBoost with ~900 miles that has an intermittent slight low speed wobble. In doing a search here I haven’t seen much on this issue so I thought maybe a thread specific to this topic would help. The shimmy seems to be more prevalent between 20-30 mph. It’s not a vibration like an out of balance tire nor is it a steering wheel wobble. It’s felt more in the seat and floor than in the steering wheel. Dealership couldn’t replicate the shimmy so they checked the rear wheel balance and sent me on my way. The tire pressures were all at 44psi so I lowered to 35psi. No real difference.
I’ve seen on a couple of threads here where some were having a similar problem where a lift had been added. Some dealers were blaming the aftermarket lift, but when the lift was removed the problem remained. My truck has no lift. One dealer found a “warped drive” and ordered parts but at this time the poster wasn’t sure what parts were order for the repair.
Is anyone having a similar issue?
ShadowBlack XL440
Robert
Northern Ohio
"Warped Drive" You driving the starship Enterprize there Scotty?
Ford Maverick Shimmy/Wobble 1674238317680
Chris_G
NOVA
C-6 Corvette
207maverick
Maine
Ford maverick 2022
Here are a few videos that show movement and the clunking noise I'm experiencing. The first two are a comparison in movement of the inner CV (where it connects to transmission). The Driver's side (where I'm experiencing the clunking noise and wobble) and the passenger side (with no noise or wobble). The last three are me pulling on the top of the tire (12 o'clock) with my foot at the bottom of the tire (6 o'clock). When I do the same on the passenger side, I do not get any movement or noise.
Driver's side inner CV moving up and down, side to side.
Passenger side inner CV moving up and down, in and out.
Driver's side inner CV. Foot at 6 o'clock, pulling back on tire from 12 o'clock.
Driver's outer CV. Foot at 6 o'clock, pulling back on tire from 12 o'clock.
Driver's side (closer look). Foot at 6 o'clock, pulling tire from 12 o'clock.
jewc75
IIRC some have found loose driveshaft bolts.
207maverick
Maine
Ford maverick 2022
Would a loose driveshaft bolt cause movement where the CV connects to the transmission 🤔
bgn
WA
There's a slight shimmying/wobble on mine as soon as I let off the gas...not great. This is probably the issue.
90south
90south
Missouri
A little update. I’ve been contacted by a Ford Motor Co. Support Manager. They spoke to my local Ford dealership and have scheduled an appointment for me to go in on 3/1. I’ll post results.
207maverick
Maine
Ford maverick 2022
@bgn @90south.
I’m in contact with someone from Ford’s social media team that has opened a case. I have also been in contact with my dealer. I’ll keep you updated as I get more information.
Deleted member 1483
Guest
I don’t know if I replied here or not, but my hybrid had an issue with the transmission mount that is causing it to shimmy if I put load on the engine. Most noticeable passing on the highway.
My dealer has ordered a part to replace. They didn’t say it wasn’t drivable in the meantime.
90south
90south
Missouri
Took the Maverick in on Tuesday 2/28 for a drive and they did feel the shimmy so I left the truck there. Got a call from the Ford Support Manager on 3/1 with a case number and to see how things went. Today is Thursday 3/2 and service writer says they have been in contact with Ford and are still trying to determine cause. I’m not sure what they have tried so far. Ford Manager is to check in with me on Friday. So bottom line is they are trying but haven’t yet found cause.
bgn
WA
Thank you for keeping us updated.
207maverick
Maine
Ford maverick 2022
I’m taking mine in on 3/17 to have it looked over. My hunch is that it’s a bad case bushing, which is causing the movement shown in the video I posted (above in thread). This video shows similar movement/symptoms on a Tacoma where the needle bearing (similar to case bearing) needed to be replaced.
Ford Maverick Shimmy/Wobble 0047440C-58E5-401C-AE71-4F68E22CC661
90south
90south
Missouri
Curious as to what your mileage is.
