Recall: 25S02 12V BATTERY INSPECTION
mavhopefull
Sam
Earth - Northern Hemisphere
1984 Mercedes Benz 300D Turbo
Update – 04/29/2025: Received a notification that the replacement parts were available. I contacted my local Ford dealer, and they arranged for a mobile service unit to install the new battery at my workplace, super convenient. A new AGM battery was installed, none of my vehicle settings were reset.
I just received an alert from my insurance app about a 12V battery inspection recall for my 2022 Maverick. Unfortunately, there were no additional details or information provided. If anyone has more specifics about this recall, please share them here.
Thanks in advance!
jewc75
I have mine scheduled for first week of Feb to go in for the recall and to find the parasitic draw that keeps killing my battery.
Manufacturer Recall Number25S02
NHTSA Recall Number25V019
Recall StatusRecall Incomplete, remedy not yet available
SummaryON YOUR VEHICLE, THE 12-VOLT BATTERY MAY EXPERIENCE INTERNAL WELD AND OR CAST-ON-STRAP FAILURES, WHICH COULD LEAD TO A SUDDEN BATTERY DEGRADATION WHILE DRIVING.
Safety RiskIF THE BATTERY SUDDENLY DEGRADES DURING A DRIVE, YOUR VEHICLE MAY BE UNABLE TO RESTART AFTER AN AUTO STOPSTART EVENT OR EXPERIENCE A STALL WHILE COMING TO A STOP AT LOW SPEED. EITHER OF THESE CONDITIONS MAY BE ACCOMPANIED BY A LOSS OF ELECTRICAL ACCESSORIES, INCLUDING HAZARD LIGHTS. A LOSS OF MOTIVE POWER CAN INCREASE THE RISK OF A CRASH. WHEN THE REMEDY IS AVAILABLE, FORD MOTOR COMPANY WILL SEND A LETTER TO INFORM YOU TO CONTACT YOUR DEALER TO SCHEDULE A REPAIR. FORD HAS NOT ISSUED INSTRUCTIONS TO STOP DRIVING YOUR VEHICLE UNDER THIS SAFETY RECALL. WHEN THE REMEDY IS AVAILABLE, YOU SHOULD CONTACT YOUR DEALER FOR AN APPOINTMENT TO HAVE YOUR VEHICLE REMEDIED AS SOON AS PRACTICABLE.
RemedyPARTS ARE NOT AVAILABLE. FORD MOTOR COMPANY IS WORKING TO PROVIDE PARTS FOR THIS REPAIR. WHEN THE REMEDY BECOMES AVAILABLE, FORD MOTOR COMPANY WILL NOTIFY YOU VIA MAIL TO SCHEDULE A SERVICE APPOINTMENT WITH YOUR DEALER FOR REPAIRS TO BE COMPLETED FREE OF CHARGE. THE REMEDY IS ANTICIPATED TO BE AVAILABLE Q2 2025.
Manufacturer's NotesTO CHECK FOR NON-SAFETY-RELATED PROGRAMS APPLICABLE TO YOUR VEHICLE, SEE HTTP://WWW.FORD.COM/ OR CALL YOUR FORD DEALER.
ShadowBlack XL440
Robert
Northern Ohio
Packer Bill
South Dakota
I just checked on my Ford Pass. I also have this recall listed for my 22 Ecoboost. The issue date is listed as 1/17/5025.
Packer Bill
South Dakota
Too bad that I already replaced Ford's lousy battery a year ago with an Interstate AGM battery. I wonder if Ford will reimbursed my expenses ($170 plus tax)?
2022 Maverick Lariat
Carolinas
I have just received the same notification as you did. I was literally going to start a thread and saw this one. My notice is word for word what you have posted. I was very dissatisfied that there is no remedy yet BUT anticipated for Q2 2025. Here’s to anticipation.
Carolinas
Thanks in advance!
Thank you for starting this thread as I am certain it will help many of us with EB and battery issues.
Packer Bill
South Dakota
The solution, imho, is a new AGM battery. I am curious what Ford is going to do...
Carolinas
In the mean time I charged my battery with a trickle charger, bypassing the BCM (directly on the posts; I know this is NOT recommended) and then reset the BCM following the procedures in the manual. Ignition on with engine off, flash high beams 5 times and then press brake pedal 3 times within 10 seconds. Saw the battery light flash on the dash confirming BCM reset. Time will tell how much, if any that helps.
Packer Bill
South Dakota
In the mean time I charged my battery with a trickle charger, bypassing the BCM (directly on the posts; I know this is NOT recommended) and then reset the BCM following the procedures in the manual. Ignition on with engine off, flash high beams 5 times and then press brake pedal 3 times within 2 minutes. Saw the battery light flash on the dash confirming BCM reset. Time will tell how much, if any that helps.
Actually, what I meant to say...is Ford going to replace these old batteries with an new AGM battery? Also I am wondering if this recall is for Ecoboost Mavs that have (or had) the EFB?
Carolinas
Ah, I gotcha. I would love to get an AGM battery and have looked around but they are a bit pricey. Also if there is a constant draw and the charging system cant keep up the problem will still be there just take longer to show. And your thought and the EFB aid a good one. I hadn’t even considered that. Either way I would really like this battery issue to be remedied so I don’t have to hear that I need to drive my Maverick more often. 😂
bgn
WA
I wish the Ford bot were still here. Maybe they could tell me who I can submit my bill to for my labor and cost of the AGM that I bought aftermarket in order to fix the issue caused by their garbage supplier QC.
Packer Bill
South Dakota
