Question/gripe about the backup cam
huunvubu
coppell tx
2023 Ford Maverick Hybrid
OP sure wants to whine more than solve the problem.
Here's your solution, with extra benefits.
A dashcam - I use this one.
The extra benefit is you'll always be recording front & rear to protect you from other idiots (and liars) on the road.
But here's the deal. Mount it with your license plate area. "Oh but that's not centered." That's okay. These use a very wide angle lens and capture a LOT of area, designed this way. How do I know? I have one mounted on my Jeep's license plate area which is even LESS centered (see pic here - https://kbdbodykits.com/images/productimages/37-6127-10.jpg). And I capture the full view behind me.
The camera also lets you decide if you want to see on screen the full rear, rear in window, etc. But it's recording both in full size.
So yes, there's an option. It's a great one. It's a cheap one (under $100, under $60 right now). But you don't want a solution. You want to whine. So just say so.
Link to B07Q5R22DV Dash Cam mentioned for users with browsers with adblock on as they block the link and only show a blank spot. This site converts amazon links to MEDIA tags and add blockers kill those.
CHORTAU Dual Dash Cam
Currently $55.23 with free shipping
JustDoIt
CK
Dallas Tx
'20 JLU Rubicon, '17 JKU Sport
THanks - had no idea. I have no affiliation, but have used this one personally. Quality is great.
Georgia
Maverick xlt hybrid
That's the case with literally every truck that has a backup camera. Idk where you expect them to put it that would allow proper camera views with full use of a tailgate. Seems like a small issue that doesn't warrant any change
Easy solution: a second cam on the upper 'wall' of the tailgate (on edge of left or right side, not in middle) that is activated by the lowered gate.
Trucklet
D
2022 Ford Maverick XL AWD 4k
A cool mod would be to put the Ford logo on a hinge so it tips out when in the lowered position. I might give that a go in the spring.
I would have to imagine that the jostling of the reversing truck / terrain would cause it to swing around like a pendulum, which would then make it freak out every time it sees the ground approaching rapidly? Check out "Rotary viscous dampers" somewhere like McMaster-Carr and use it in tandem with gravity so that you can have the emblem hold vertically without jigglin'.
dgnx6
Louisiana
Hi all,
I have been loving my new Maverick, it has been doing lots of truck work (moving furniture, etc) that could never have happened with our SUV. Also, it has been cold and snowy up here, and the AWD with stock tires has been amazing!
One of my biggest gripes though, is that the backup cam is useless when the tailgate is down and you are in reverse. Worse than that, it sets off the back-up impact warning, because it thinks that you are going to hit the ground (with the camera now aimed directly at the ground).
Has anyone looked at repositioning the backup cam somehow so that it remains functional with the tailgate down?
Thanks for sharing any advice.
I just dont understand where else you put it. My back up cam is worthless on my current vehicle with the trunk open. It just points at the sky.
dgnx6
Louisiana
Great price, but quick question. So if you mount it on the bumper or license plate. Wouldnt the tailgate being down block the upper portion of your view anyway?
JustDoIt
CK
Dallas Tx
Good questions... This has a VERY wide angle lens from all directions.
Here's where it's mounted - VERY farthest outside corner, that tiny little square at the bottom of my license plate area.
Ford Maverick Question/gripe about the backup cam IMG_1636.JPEG
And here's what the image looks like in a parking space back to back with another car (upper right is the reverse, rest is the front view) which I guess would be 2-4 feet bumper to bumper? - very clear, very visible details, and you can see the ground, peripheral, etc.
If there IS some restriction from the tailgate, you could still clearly see the ground immediately behind and a lot more visibility than any other method.
Ford Maverick Question/gripe about the backup cam IMG_1635
Evil2ltr
Kevin
Asheville, NC
2022 Alto Blue Maverick XLT AWD
Not many Mavs have the back up sensors.
Another Ford mis-step on these.
ddhill
New Hampshire
2022 Maverick XLT
Larrythelunatic
Larry
Massachusetts
If you’re really moving heavy furniture, unless you’re Man Mountain Dean, you’re probably not working by yourself. So get your partner to get the hell out and look behind you! Duh!
