Maximum Spare Tire Size
jspa
Jeremy
Cumming, GA
Hyundia, Santa Fe Sport
One of the first upgrades that I did to my Maverick was a 2in level/lift and put larger tires on. The tires I put on are 245/70/R17 BFG KO2s.
As part of that upgrade, I wanted to add a spare that is the same size as the rest of the tires. When I measured the spare tire well, It was going to be close, so I took a chance. I ordered a steel wheel off ebay that was 6.5 in wide and the correct lug pattern (roughly $85). I then went to a local used tire shop and found a used 245/70/R17 ($45 installed and balanced on the rim).
Then the moment of truth. . . IT FITS . . . Well, sorta. I did have to re-locate some wires that were getting pinched towards the front of the vehicle. I think it is safe to say that this is the largest tire size you can fit in the spare tire well. And it would probably be close if you had a new AT tire with more tread.
Hopefully this info and the attached pictures will help answer some questions out there. I tried to document the sizes, tolerances, and the wires that needed re-locating.
Ford Maverick Maximum Spare Tire Size Photo Apr 12, 5 01 45 PM
Ford Maverick Maximum Spare Tire Size Photo Apr 12, 5 07 48 PM
Ford Maverick Maximum Spare Tire Size Photo Apr 12, 5 09 41 PM
Ford Maverick Maximum Spare Tire Size Photo Apr 12, 5 13 00 PM
Ford Maverick Maximum Spare Tire Size Photo Apr 12, 5 14 23 PM
Ford Maverick Maximum Spare Tire Size Photo Apr 12, 5 14 26 PM
Ford Maverick Maximum Spare Tire Size Photo Apr 12, 5 14 31 PM
Ford Maverick Maximum Spare Tire Size Photo Apr 12, 5 14 38 PM
Ford Maverick Maximum Spare Tire Size Photo Apr 12, 5 14 45 PM
Ford Maverick Maximum Spare Tire Size Photo Apr 12, 5 15 00 PM
My1stFord
North Idaho
Subaru
It is good info for those looking to do the same.
For me, I think I'd the donut spare. As I don't plan on off roading this thing.
gagonoy
Greg
Oahu, Hawaii
2022 Ford Maverick XLT, FX4 package.
Great information. I also upgraded to 245/70R17 tires. I payed for a full size spare, so i think all i need to do is change out the tire size. Some key points to know is to get a used tire to make sure some of the treads are worn down a bit and the re-routing of some wires. But it’s great to know it is possible to to have a 245/70R17 spare in the spare well. (y)
jayrx7trbo2
Jay
largo Florida
2022 fx4 maverick
that means i should be good with 245/65/17 for a spare if you can fit the 70 series :cool:
Lynyrd Skynyrd
22 Maverick
Maybe I missed it. Did you cut off or bend the points that are there for rear end collision? I couldn’t fit a 225 in that spot and let it go as I’m not a fan of the gas tank blowing up incase some moron hits me
Ford Maverick Maximum Spare Tire Size D412F0A7-C112-4581-9787-4597E40FFA34
Hot Runr Guy
West Chicago, IL
I'm glad you asked, considering we just had this conversation a couple of weeks ago,,,,
HRG
Hot Runr Guy
West Chicago, IL
@jspa, Can you jump in?
HRG
jspa
jspa
Jeremy
Cumming, GA
I did not make any structural changes to the vehicle, all I did was relocate a wiring harness.
Lynyrd Skynyrd
22 Maverick
Maybe mavericks are built different. Could not fit a 225 under mine.
That and others had to lop it off for a 235. Amazing
Nw_adventure
Salt Lake city
I need to sort this out- Will measure things out tomorrow- Would like a 245/65/17 spare to match-
NoVaJimmy
KCMO
Lexus GX 460
I finally got around to testing one of my 235/65R18 wheel/tires in the spare tire area and no way it could fit without cutting out the serrated sheet metal part designed to pop the tire in a rear end impact. No thanks. Seemed like you could also do something janky and wedge the tire in front of that piece but the engineers designed and placed it there for a reason. Not sure how other people are getting larger spares to fit there without cutting that piece out. Maybe it's a tow hitch thing? Does the 4k tow package have a more beefy hitch? Maybe the larger spare tires fit without the tow hitch in the way?
thevol
GA
Iconic Silver Mav 2.0 AWD 4k
Can you take another pic showing the clearance between those teeth and the tire?
