- First Name
- Jeremy
- Sep 29, 2021
- Cumming, GA
- Hyundia, Santa Fe Sport
- Engine
- 2.0L EcoBoost
One of the first upgrades that I did to my Maverick was a 2in level/lift and put larger tires on. The tires I put on are 245/70/R17 BFG KO2s.
As part of that upgrade, I wanted to add a spare that is the same size as the rest of the tires. When I measured the spare tire well, It was going to be close, so I took a chance. I ordered a steel wheel off ebay that was 6.5 in wide and the correct lug pattern (roughly $85). I then went to a local used tire shop and found a used 245/70/R17 ($45 installed and balanced on the rim).
Then the moment of truth. . . IT FITS . . . Well, sorta. I did have to re-locate some wires that were getting pinched towards the front of the vehicle. I think it is safe to say that this is the largest tire size you can fit in the spare tire well. And it would probably be close if you had a new AT tire with more tread.
Hopefully this info and the attached pictures will help answer some questions out there. I tried to document the sizes, tolerances, and the wires that needed re-locating.
