Maverick XL High Idle At Startup?
Long Time Ford Guy
2025 Ford Maverick
Is it normal for my Maverick XL base model, 2.0 L EcoBoost Turbo gas 4 cyl engine to idle a bit high at startup for about a solid minute or two, then drop down to low idle on its own after the engine warms up? In warm weather? I don't drive off until the engine idle lowers. Is this normal engine behavior at startup?
Meeka
Jay
Castlegar B.C. Canada
2024 XLT 2.0 turbo
My 24 XLT 2.0 Eco has done this since new, yes normal.
Chops
Lobo
Not sure what kind of engine temp gauge you have, but my 25 high idles & ends with the “needle” moving from blue to red. Takes a minute or so. I heard it is to get the cats warmed up to do their job properly…
Mikeske
Michael
Washington
Since all most all engines will have a slightly high idle because the computer runs a bit rich at cold start. This normal as in the old carburetor days we had a high idle circuit and a choke. Just normal behavior to prevent the vehicle from dieing at start up.
Maverick123
Waiting
As mentioned by @Chops on modern cars the fast idle at startup is to light off the catalytic converter(s) faster
Gray Goose
RG
Wissota
Not just modern cars. All internal combustion needs a richer fuel to air ratio at startup. Before electronic fuel injection, there was auto choke on the carburetor. Before that was a manual choke. Before that, the horse needed some extra oats on cold mornings. :)
F100Lobo
Montreal
1977 F100, 2013 Focus, 2025 Maverick Lobo
The high idle allows the engine to get up to operating temperature as quickly as possible.
Also, when the engine is at high idle the injection timing allows some of the combustion flame to exit the exhaust ports in an effort to get catalytic converter up to operating temperature.
It's all done for the strict emission rules.
Meeka
Jay
2024 XLT 2.0 turbo
Even tho it’s warmer out for now (and I park in a garage) I still let my Eco ‘warm’ up for a minute or so until the high idle drops, not even a minute before I take off. Winter I do the same but it takes a little longer for idle to drop, of course. Gotta look after my Turbo! 😉
F100Lobo
Montreal
The best cold start procedure, no matter the ambient temperature, is to let the engine idle for about 15 seconds, which allows the oil to circulate completely and then drive slowly until everything is up to temperature.
This allows the whole drive train to warm up equally.
Chops
Lobo
I agree with you about those easy miles at first, but 15 seconds of idle isn’t nearly enough time for me to finish my pre-drive routine without stress!
I start my Maverick and buckle up my seatbelt. I will clear the happy seatbelt icon then pick the “Mode” I’ll be driving in at first. Sometimes I’ll check my tire pressures even though I did a visual before entering truck - just to calibrate my eyes with what the TPS is showing. Then I’ll connect my iPhone and get my destination set up. If no destination - I’ll hit the button to show me time & date. Am I forgetting any important birthdays today? Maybe a last minute check of texts etc before I’m driving. Also do a mental check to make sure I have everything I need for my drive.
The high idle is typically over by this time - if not I’ll take a deep breath or two & meditate. Never a bad idea I think.
But it is still critical to drive easy for a few miles to let the oil reach the proper temperature - even after the brief high idle.
Although, my easy miles should be a bit shorter than yours. As you are reaching the proper oil temperature you might see me in your rear view mirror catching up to you. Focused, organized, and stress free.
Marcacox
Marc
Kansas
2025 Maverick XLT
It allows the catalytic converters to get to temperature
Marcacox
Marc
Kansas
2025 Maverick XLT
F100Lobo
Montreal
