Maverick uses same hybrid system as escape? Any 12v battery issues?
StillWaiting
Brandyn
St pete
2009 Dodge Challenger SRT8
So is the battery under the seat the only battery and the one that powers the electric motor when the hybrid is running off electric power only or is there a second battery elsewhere?
Yes there’s two batteries, both different. Even Tesla has a 12v.
JBnorthTX
Jay
DFW
2019 Mustang, 2013 Honda CRV
Hopefully they've worked out the kinks. I just replaced my OE 12v battery on my 08 Toyota Prius at 186,000 miles. Hopefully the Maverick's lasts just as long! 🤪
Wow. I go through batteries every 3 years. I think the Texas heat kills them. They usually cost next to nothing to replace under warranty.
Benson
Benson
Maverick Hybrid XLT
I would never bet on a Ford 'anything' outlasting Toyota .
How much $$ was your new Prius battery?
icegradner
British Columbia, Canada
2022 XLT Maverick Hybrid
The stock Panasonic AGMs Toyota supplies are not cheap, but you sure get your money's worth. Here in Canada the Panasonic AGM is around $500. A normal car battery would likely be $150-$250 depending on size. Then again, that normal car battery might hold up 3-5 years, vs 10 or more. Crazy.
Benson
Benson
Maverick Hybrid XLT
I;d glady pay $500 to get the superior performance .
fbov
Frank
Bushnell's Basin
2020 Escape Hybrid
Exactly right. Heat kills lead-acid batteries. Per AAA...
" In cooler northern climates, a battery may last five years or longer, but in hot southern locales, a car battery will typically last approximately three years. "
Benson
Benson
Maverick Hybrid XLT
So hybrid battery in Maverick is old-fashioned lead? Why isnt it L-ion?
raymaines
Ray
Tacoma, Washington
Alto Blue Lariat Lux Hybrid
The Hige Voltage (the "second") battery is the bigger, flat, square thing in the picture above this post.
BILLNOROVILLE
NorCal
prius, Hybrid XLT, Honda 1100Rebel, 2) Hawk 650NT
I own a 2016 Prius and it's oem battery lasted only about 4 years. 179.00 for a replacement. 129.00 at Autozone with same warranty. Not impressed. I like my Prius and like my Maverick. Hybrid's don't work when 12 volt battery dies. Easy fix.
Traction batteries in either will cost thousands. So far Prius is fine.
icegradner
The High voltage battery for the electric drive system is Lithium Ion, we are talking about the 12 volt battery, which yes is a AGM Lead acid battery. Most likely due to price. A Lithium 12v battery likely costs 2x what a AGM does.
SolidWrecks
SolidWrecks
Metro Detroit
Maverick Hybrid Lariat Lux
Does the 12V battery see large loads? I think the car s started with the HV battery. Thoughts on a Lithium replacement like a power queen? I am looking at putting a 2000w inverter in my truck and would like to make sure I'm not going to hurt a lead acid battery.
garnermike
north carolina
Outback, Niro Hybid, Corvette, Fiat Spider
Yes. 12-volt battery issues on my Mav. None for the first 6 months (3000 miles). But then the dome interior lights and intelligent door-handle access stopped working. Then the lane-change alert worked only intermittently. To get those driver-convenience things working again, I would have to charge the 12v battery myself (and then deactivate/reactivate the lane-change system).
Am picking up the Mav from the dealer today (hopefully). They told me that 12v battery was low on voltage and wasn't charging, so they replaced it under warranty. I won't know (and they don't know) if the new 12v battery will fix the issues I described above. Will need to drive it to find out.
GPSMan
Many
It will be interesting and important to know:
Were some shipped out with weak or defective 12v batteries?
Or were some shipped out with weak, undersized, mis-programmed or whatever charging systems?
Automate
Atlanta GA, USA (ATL)
Fusion Hybrid, Mav XL Hybrid
Probably some of both plus a 3rd possibility.
Some modules are not fully going to sleep with the vehicle is off. Therefore using too much 12V battery power as the vehicle sits.
