Mach-E Brembo Upgrade with Part #'s
AUsomTiger
Sweet Home Alabama
2025 60th Anniversary Mustang GT BB #0073, 2022 Maverick Lariat
I have the Mach e calipers as of today I’m just thinking of the potential of what other focus mk4 parts are able to bolt on like a turbo?
I went with a Lincoln Corsair Turbo since it's a direct fit. Lots of options depending on your budget. Can get those off the used parts sites too.
stangg17
Chicago
I need to know more. Is it just a direct swap? No software?
AUsomTiger
Sweet Home Alabama
AUsomTiger
Sweet Home Alabama
I didn't realize you were on a 22. I'm in a LOBO and very little tuning options nhencr why I was surprised.
HP Tuners is now supporting tuning on 25+ Mavericks. That's who my tuner uses. That said, there are some changes to the engine that could impact the turbo options so more research would be needed.
Hot Runr Guy
West Chicago, IL
This might be false Mach e Cali came with 18s I will be test fitting my stock 18s soon just need to figure out my purge valve code
Keep in mind, there are multiple Mach E GT brake packages being discussed in this thread. The larger rotors are from the "Performance Edition", Mach E GT's (non PE) use a slightly smaller rotor. Those may be the ones that fit within 18's.
HRG
MGouin
MGouin
F150 FX4, Early Bronco, Jeeps, Lots of Motorcycles
Maybe. The smallest I have seen are 19”.
Ford Maverick Mach-E Brembo Upgrade with Part #'s IMG_5335
metomwhou
Stuttgart, Germany
2021 C8, 2016 HellCat, 2014 Nissan Frontier-V8
HRG
This is true, I've seen both 362mm and 385mm being discussed here. So I went down the rabbit hole this morning....
***Keep in mind that the part numbers I reference are from the white sticker affixed to the caliper itself***
This is the breakdown of what I've been able to figure:
The Mach-e and Mach-e GT (non-performance) come with either a silver or red (GT) caliper and appear to be the same caliper with two different colors and part numbers and use the same 362mm rotor.
Silver calipers are:
LJ9C-2010-FEB-RF (2021 and older)
LJ9C-2011-FEB-LF (2021 and older)
LJ9C-2010-FEC RF (2022 and newer)
LJ9C-2011-FEC LF (2022 and newer)
2021 - 2024 FORD MUSTANG MACH-E FRONT LEFT DRIVER SIDE BRAKE CALIPER OEM | eBay
Red Calipers are: (apparantly red paint is SUPER expensive...)
LJ9C-2010-FLB RF (2021 and older)
LJ9C-2011-FLB LF (2021 and older)
LJ9C-2010-FLC RF (2022 and newer)
LJ9C-2011-FLC LF (2022 and newer)
LJ9C2010FLC Ford Mustang Mach-E Bremsscheiben und Bremssättel eingestellt, 952,73 € | OVOKO
The following calipers "look" the same but have different part numbers and are shown with 385mm rotors:
LK9C-2010-GLD RF 2025 model
LK9C-2011-GLD LF
Ford Mustang Mach-E 2025 Electric Brake Discs and Calipers Set | eBay.de
LK9C-2011-GLC RF (385mm rotor shown) 2021 model
LK9C-2011-GLC LF
LK9C2010GLC Ford Mach-E I Bremsscheiben und Bremssättel eingestellt, 600,00 € | OVOKO
Other than different part numbers and paint, ALL of these calipers appear visually identical.
I can't figure out if there is actually a difference between the LK9C(using 385mm rotor) and LJ9C(using 362mm rotor) series.
If they are the same, then either rotor should work and the rotor size should not have anything to do with how large of a wheel is required since the caliper would be mounted the same. Far as I can tell, the only difference might be the spacer required to center the caliper on the rotor fore/aft rather than up/down where there is no adjustment.
I purchased an LJ9C-2011-FEC LF Caliper last week to see if it would fit inside under my 18" stock wheels(2023 lariat) and will report back what I find in a few weeks.
Lastly, from Brembo's website, they indicate that 385mm rotors are used on BOTH Mach-e GT and GT Performance cars....so your guess is as good as any.........
Brembo brakes on Mustang Mach-e GT and GT performance | Brembo EN
JasonGoz
Jason
LK9C-2011-GLD LF
LK9C-2011-GLC LF
I bet the steering Knuckle bolts the caliper farther out on performance . Same size caliper. I think the only rotor that is used for us is 363
Grammaton
Ross
Covina, CA
2023 Ford Maverick AWD Lariat BAP 4K CP360+Assist
LK9C-2011-GLD LF
LK9C-2011-GLC LF
I went looking for new Calipers for the Non Performance Pkg from various Ford OEM's and Rock Auto and found these parts numbers for 2021 to 2024 Mach-E's. Note any part that begins with LJxx is for the Non Performance Pkg with 362mm Rotors. LKxx are for the Performance Pkg with 385mm Rotors.
Calipers Mach-E 2021-2024 (RockAuto) (OemFordPartsDirect)
(Non-Painted Silver) w/o Performance Pkg fits 362mm Rotors.
Driver Side: BRCF-612 or LJ9Z-2B121-J (Replaces LJ9Z-2B121-A)
Passenger Side: BRCF-610 or LJ9Z-2B120-J (Replaces LJ9Z-2B120-A/LJ9Z-2B120-F)
(Painted Red) w/o Performance Pkg fits 362mm Rotors
Driver Side: LJ9Z-2B121-H (Replaces LJ9Z-2B121-B)
Passenger Side: LJ9Z-2B120-H (Replaces LJ9Z-2B120-B & LJ9Z-2B120-G)
Mach-E 362mm Plain Rotors (RockAuto):
Brembo KT08026 Beyond EV; Enhanced Corrosion Resistance Rotors & Ceramic Pads for EV/Hybrids $328.78
Ford OEM BRRF-469 or LJ9Z-1125-B $104.79
Dynamic Friction 60054295 $48.79
Wagner BD181250E $63.79
Dynamic Friction GeoSpec 60454295 $56.79
Raybestos 682744FZN Element 3 $86.79
Power Stop AR85211EVC Geomet Coated $63.79
Dynamic Friction 90054295 Hi-Carbon Alloy GEOMET Coated $72.79
Mach-E 362mm Drilled & Slotted Rotors (RockAuto):
R1 Concepts Zinc Silver 63154295L Front Left Rotor $89.89
R1 Concepts Zinc Silver 63154295R Right Front Rotor $89.89
R1 Concepts Zinc Black 63354295L Front Left Rotor $100.79
R1 Concepts Zinc Black 63354295R Right Front Rotor $100.79
R1 Concepts GeoSpec Silver 83054295L Front Left Rotor $104.79
R1 Concepts GeoSpec Silver 83054295R Right Front Rotor $104.79
Power Stop AR85211XPR Extreme Performance Drilled and Slotted Front Pair $135.79
Mach-E Brake Hose (RockAuto):
Motorcraft BRHF-281 or LJ9Z-2078-A $32.99
