Low coolant and oil
dalola
Retired
SE Ohio 🇺🇸
You mentioned early on you did not confirm oil level when new, so you *may not* even have an oil problem.
Did you ask the servicing dealer how/why they determined a defective radiator is the cause?
Mvrck
E
After they flushed the coolant they said there was still a lot of aluminum filings in the new coolant.
fossil
ernie
ohio
sounds like a water pump self destructing.
AltoBAP
Jefferson
Metro Detroit
2020 Ford Fusion SE 2.0 AWD
If you truly have aluminum pieces in your coolant, your dealer should be contacting FoMoCo.
Ford can take a sample of the coolant and analyze it and determine exactly where the aluminum is coming from.
Seems odd they are just throwing a radiator at it.
Mvrck
E
Update : about 800 miles after the radiator replacement my engine coolant tank was below the minimum line and the oil is about a half quart low. It's back at the dealership awaiting diagnosis.
OleFordGuy
This is not sounding very reassuring
flashfearless
Alan
2022 Ford Mav Lariat Hybrid,2014 Ford Edge Limited
No, my oil life is still over 50%
Don't go by the guidance system. Change your oil around 5K miles or 6 months. Always.
Montana
This. At most, a yearly regiment for those who don't put that much mileage on their vehicles. Very few people use their vehicles for the "recommended service levels". If you ever read the manual, you'd see that means a majority of highway miles (90% or greater) and majority of flat roads with very little idle time. Recommended service intervals are perfect scenario recommendations.
5-6k max for oil or at least once a year.
Veer
veer
New Jersey
Ford Maverick Hybrid
what was the outcome? Was the leak found?
