Loose leather steering column "curtain"-- really, Ford?
Blue_Max
Orlando, FL
How so? Your XLT has tilt/telescoping steering, so it has the same vinyl cover shown in the OP.
Ha! I had to go check. I just never noticed it before, but it's there. It's black, and I guess mine is installed correctly. I thought it was all hard plastic.
I've never spent any time examining the steering column before.
Tbone289
They're all installed correctly. People just assume that they should be attached on the sides.
Little boy blue
Okeechobee FL
1995 ranger but getting a 2024 Maverick.
First off, loving the truck. Yeah, a lot of interior stuff is cheap, but it feels honest, none of it is bothering me yet.
... except for this, which I only noticed a week or so into ownership, and welp, I finally found an extraordinary Maverick cheap-out that stunned me. I've NEVER seen something like this in any car or truck I've ever driven in nearly four decades of motoring, including some of the cheapest penalty boxes sold in America. Like, who just gives up and puts a curtain on a steering column? Lada? Yugo?? What kind of money does this even save for you, Ford?
Now, it wouldn't bother me half as much if the curtain (or cover, or jacket, or drape... anyone know the technical term for this part? Couldn't find it listed in any Ford parts schematics online) wasn't detached from both ends, hanging loose (see this thread for a clearer example: https://www.mavericktruckclub.com/forum/threads/top-steering-wheel-column-to-dash-cover.51786/). The best I can do is kind of tuck in both ends, but it still pops out. It doesn't shift out unless I adjust the steering column, but expecting my better half to need to do that whenever she borrows the truck, that means this thing's gonna shift out often.
Anyway... griping aside... as ridiculously minor a thing as this is, is this still something that can be fixed under warranty? While I change my own oil, I'm going to at least get my first service done at a dealer just so they have to face the rumored hassle of taking off the filter for the first time, so I'm wondering whether this is something I can ask them to address while I'm there... or am I only now discovering a Maverick flaw ("quirk," if we're being polite) that we all just live with?
🤣 I just noticed that issue with mine last week while driving, now i can't unsee it🙄. I'll mention it to them this week when I drop it off for the airbag lamp issue.
RyuRonin1977
Tristen
Virginia
2025 Ford Maverick
Ask @MABETT to design one for us. : )
BlueSpec1
Gene
Part seems to be sold as part of the IPC Cluster Bezel Panel Instrument
NZ6Z26044D70AB
I had guessed it would be part of the Steering Column Cover Shroud
https://parts.ford.com/shop/en/us/b...eering-column-cover-shroud-p-lj6z3530ba?pdp=y
SKU: LJ6Z-3530-BA Positions: Upper Other Names: Shroud, Upper Shroud, Shroud Assembly Steering Column Description: Escape. Upper. Bronco Sport. With keyless entry/start. Maverick.
Steering Column Shrouds - 501-05 Interior Trim & Ornamentation
1. Fully extend and lower the steering column
2. Release the tabs and position the gap hider aside
3. Release the upper steering column shroud front clips.
Instrument Panel Cluster (IPC) - 413-01 Instrumentation, Message Center and Warning Chimes
2. Fully extend and lower the steering column.
3. Release the clips and remove the gap hider from the upper steering column shroud.
1. Remove the bolts.
2. Release the clips and remove IPC trim panel.
Cluster Bezel Panel Instrument NZ6Z26044D70AB
https://parts.ford.com/shop/en/us/b...bezel-panel-instrument-p-nz6z26044d70ab?pdp=y
Ford Maverick Loose leather steering column "curtain"-- really, Ford? 1753053170715-lz
The Real DIY How-To Replace Xl/XLT Cluster with a Lariat Cluster, and 1 question...
Daveinva
Daveinva
Washington, D.C.
2025 Maverick Lariat Eruption Green
Ford has been doing this for at least 25 years in vehicles that have tilt/telescoping steering columns.
Wait-- Ford does this on their more expensive vehicles too? Yeesh.
I'm not sure what you're expecting to see here. How would you suggest that this area be covered while allowing for the wide range of tilting and telescoping of the steering column?
I don't know-- without a vinyl cover? Like the tilting and telescoping wheel in my girlfriend's Subaru Forester? Or the tilting and telescoping steering wheel in the Mazda CX-7 that I used to own? Etc., etc. All had hard plastic covers. Sensing a trend, I hope.
There's no need for a cheap vinyl shroud had Ford merely designed a column that didn't need one, like every other car and truck I've owned in the past.
Again, not a big deal by any stretch; I'll live with it. Just a weird thing I've never seen before, because I clearly have never owned a Ford before.
Tbone289
I never said it was in more expensive Ford vehicles. It's in all of the economy C-platform vehicles like the Maverick and Focus. If you wanted a vehicle with nice interior materials, why did you buy a Maverick? That's certainly not its forte, and I don't consider any of it on par with a Forester or CX-7.
dochawk
doc
Las Vegas
You folks all have it wrong; it's a hidden feature that wasn't enabled.
Use forscan to enable "tire inflation while underway". What you're seeing is the bellows; you pull the wheel up and down to inflate!
Now the base option is cloth with vinyl as the premium option, and it was the opposite decades ago.
Going back to not so recently, cloth was the fancy new upgrade for seats.
So there's a lot of 1930s or so Cadillacs, Packards, and such with leather front seats and cloth back seats--because folks weren't wasting fancy seats on their driver, and only put them in back where the owners rode!
samspritzer
Sam
Buffalo NY
2019 CRV
Another one for The Joys of OCD books....
