Bushpilot
Greg
Spokane, WA
Chevy Volt
Maverick2022XL
name
hinterlands
stlouischiefs
Saint Louis
Hyundai Santa Fe, Cactus Grey XLT on order
Tried ordering from the local ford dealer as well as Tasca Parts. Both were canceled due to nationwide back order. Ordered off ebay, hopefully that one comes in.
Sirslayer
Victor
I’m not too surprised!! I had a flat tire on my stock tires and there is no replacement part in the Southern California area!! I had to purchase a very similar brand size of tire !
Kaytu
Brevard County, FL
2022 Velocity Blue Maverick XL AWD
So close to getting this working, but the PSCM just won't take. Digging through other As-Builts hoping to find an alternative.
maxpaine1337
South Carolina
F150
Anyone know if lane centering can be enabled on XLT with co pilot 360. I know it has Lane keeping but it would be nice to have Lane centering like on the Lariat.
LionRampant
Lyon
Sarasota
I've got the same problem. Let me know if you find a fix!
Maverick2022XL
name
hinterlands
I posted the wrong address in the main post.
it should be
PSCM
730-02-02
FFFF 0000 0039
It has has been corrected.
The code works in the following manner.
**xx-xxxx-xxxx
Those 2 are for Lane Departure Warning.
00=off
FF=on
xx**-xxxx-xxxx
Those 2 are for the Lane Keep Aid
00=off
FF=on
Maverick2022XL
name
hinterlands
No, at least not as it is built out of the factory. Lane Centering requires the lower radar sensor which is used for adaptive cruise control.
KenT
Ken
UT
2018 Honda CRV
If the dealer calls and says you can get your Maverick this model year if you drop Co-Pilot 360, and you counter that I will drop the package if you re-program the IPMA module to enable Lane keeping Assist, and install the turn signal stalk required, do you think the dealer would do that? Would their service department even know how? How else could a customer get this done; not to stiff Ford, but to partially compensate for Ford’s inability to build the CP360 package ordered?
Maverick2022XL
name
hinterlands
No even if they did have an exact config from Ford to program it partially.
Eagle11
Valley of the Sun
NOPE.... The liability falls on the dealership if ANYTHING would happen.
MaveK
Peter
Maverick 2.0
I assume you mean standard cruise control if adaptive I'll post the codes over in my DIY thread at some point.
I do have space reserved in there for ACC modding. If anyone buys the parts I'll be more than happy to share what codes I know do and should work with them as long as they are willing to confirm the end result works.
The original cruise control upgrade thread by @Tyvemattis has gone all over the place but it is a good place to start. I put together and more compact version over in the DIY section.
Can you help me accomplish the retrofit of the acc on my xlt Maverick?
I went to the dealership parts department and I got a list of parts but I don’t know anything about programming!
OORAH
Shane
Shawnee, OK
Ok, have the switch installed and PSCM will not change. Get the error "Service procedure has been interrupted".
I have successfully changed all the other codes and also have Cruise Control and TSR working.
2022 XL EcoBoost No 360
FORScan v2.3.47 test20220406
OORAH
Shane
Shawnee, OK
Ok, for those interested. Contacted FORScan, sent them the log files and very quickly got a new build of FORScan to install. (FORScan v2.3.48 test 20220423) Everything worked like a charm.
On my XL I now have:
Traffic Sign Recognition
Lane-Keeping System
Cruise Control
Engine Hours
Front and rear dash cam hard wired in
Locking Tailgate on back order.
With the exception of the tailgate, everything is working as it should with out any errors or problem.
