Keeping storage items from sliding forward in the bed
Lexiewtoad
C.
San Clemente, CA
2025 Lariat
I am looking for a way to keep items near the tailgate for temporary storage in my 2025 Lariat with a bed cover. Any suggestions
ABTremor
NC
2023 Tremor
I keep one of those spring loaded adjustable shower curtain rods in the bed for just that purpose. It works well for most loads, although a really heavy item will probably bend it in half 😄
ETA: you can also cut a 2×6 to fit in the side bed pockets if a sturdier option is needed.
Hunters Edge
Sid
F150 crew
I have a spray in bedliner that keeps the majority of items were they are unless my driving habit has changed. Having a flex bed just a properly cut to length 2x6 in the first set of slots makes a difference divider or divides the bed up to keep things near the tailgate.
I liked that and was planning on that before taking delivery. Afterwards many items that I keep in the bed jack stand, hydraulic jack, jack's handle, hitch extension, two hitch receivers all stay in place. The only item is the jack sometimes rolls forward. I keep a 1x2 with a screw for a hook from my F150 in the back. It lays flat to the side for easy access and allow large items to stack on top. The few times may be twice in a year that it has rolled forward I ha e used that stick to easily bring it back. So I never actually used a 2x6 or found a need to divide the bed. I'm thinking the spray in bedliner is the reason for this. Or I have been driving really, really good LOL.
I have a pull-out tray that gives me more storage area than a 2x6 would give me in the cut-out area.
Like me, it ain't pretty but it's still functional. It's no show truck.
Ford Maverick Keeping storage items from sliding forward in the bed IMG20240909122313
It holds more than using a 2x6 across.
Ford Maverick Keeping storage items from sliding forward in the bed IMG20240720123552
In less than 30 seconds you can pull the 2 side brackets out and it lays flat for large items. You don't have to find a place to store it, if you need to use the whole bed, like you would a bed extender.
Ford Maverick Keeping storage items from sliding forward in the bed IMG20240720122803
It pulls out for easy unloading.
Ford Maverick Keeping storage items from sliding forward in the bed IMG20240720123129
I tried the 2X6. Too heavy for me and cumbersome even with the hinge. It only gives you 15 inches of space and stuff still fell over the top it's just not enough storage for me.
And I still had a bend over the tailgate in order to remove the items.
Ford Maverick Keeping storage items from sliding forward in the bed IMG20240909121324
I found the extending bars to still allow stuff to slide underneath.
L30n1d45
Nebraska
2025 Ford Maverick 2.5L Hybrid AWD
I got a 2x10 from Home Depot and cut it to 54.25". Fits across the bed and into the slots on the sides perfectly.
Redline
Upstate, NY
Ford's sliding bed divider works really well for that. You also need to have the Cargo Management System rails to mount it. It's a little pricey compared to a 2 x 6, but it's really nice and works great.
Ford Maverick Keeping storage items from sliding forward in the bed IMG_20240709_112642475
MaverickMark
2023 Maverick Lariat
I bought a cargo net that spans across the bed. It's great for groceries, etc. It's inexpensive and keeps everything in place.
Tbone289
I like a basic ratcheting cargo bar. Combined with some collapsible storage crates, it handles loose items and can be quickly reconfigured on the fly to stow bigger stuff.
+1
This is exactly what I do, and I use the collapsible InstaCrates as well. I combine those with milk crates at times (usually to hold a 20lb propane tank or heavy recovery gear) and coolers. I use RopeRatchets to secure the crates/coolers to the bed and the cargo bar to keep them in place.
The cargo bar can be located anywhere, but it locks really tightly into the flexbed slots.
Combining this with c-channel tie-down rails will allow you to tie items down in virtually any configuration:
Little boy blue
Okeechobee FL
1995 ranger but getting a 2024 Maverick.
In less than 30 seconds you can pull the 2 side backs out and it lays flat for large items. You don't have to find a place to store it if you need to use the whole bed.
I think your on to something there 🤔
