If you build out your engine...
Bigcanoe
Moncure, nc
2025 Maverick XLT, 2022 Toyota Rav4 Hybrid
Will AWD be better for keeping the tires on the ground and using the additional power? Kind of like the VW GTI vs the Golf R?
Dueces
It really doesn't matter if you have "extra" power or not, having the rear wheels engage will always be a net positive on traction. Your question is very confusing.
Bigcanoe
Moncure, nc
You think? Even on dry roads? I know with a tuned GTI the FWD can spin pretty easy and with no AWD its a power loss.
Dueces
it's not a power loss, it's an acceleration loss. I'm still confused on what you are actually asking.
From what I have gathered, the AWD adapts so fast, you won't even notice the front spinning before the rear kicks in, on these trucks.
Even with my CR-V, which only sends about 15% to the rear, it's better than just FWD.
Bigcanoe
Moncure, nc
I am trying to decide if AWD is worth it for me I guess. I dont have much snow or ice, and FWD would be probably good enough. But just curious if I was to tune the engine or something if I might find I miss not having it. Just options!
whtnrdy
Chicago
'05 AWD Astro, '90 G20 Van, '22 Maverick XLT
Depends on what you exactly mean by building it out, and what your application will be for using that extra power. The AWD in the R is going to be more for handling tracks, not straight line. And I also would assume that the AWD in the Golf R is designed specifically for performance on the track (not snow), which the Maverick system would not be.
jwilson
NJ
PENDING MAV XLT/Hybrid
Bigcanoe
Moncure, nc
I read the suspension was different for the rear (obviously) with the AWD too. So it may handle better on the curves.
whtnrdy
Chicago
Yes, the FWD is a torsion bar system so the AWD's fully independent rear would be an improvement.
Brian_J
Akron, Ohio
'22 HPR Maverick AWD 4K LUX
Yes, you want awd if maximum forward momentum is your goal. There was a FWD test drive video where they smashed the gas w traction control off and it spun the tires a lot stock.
Now, if you like to do freeway pulls from 50 in Mexico, then you might be ok w some sticky front tires or drag radials if you run a big turbo.
Kriston
Kriston
Colorado
definately not gonna want fwd if you want to put any serious power down. im spinning all four with the slightest amount of dust on the road.
Evil2ltr
Kevin
Asheville, NC
2022 Alto Blue Maverick XLT AWD
Put it this way, if you think you will " build " it out to 300hp or more, get AWD
inthecabin
Andy
2021 Ranger Lariat FX4
Doesn’t AWD kick out over a certain speed and back in under a certain speed? Otherwise it would be 4WD.
Just curious 🤨
