Hybrid battery voltage meter .
clavicus
I figured out how to cast it from my phone to the screen. So, I plug the adapter into the obd2 spot( drivers side under dash). The adapter connects via Bluetooth to my phone. I plug my phone into the radio via USB.
I don't have any idea how or if it's possible to do that from iphone.
Here's the apple app:
https://apps.apple.com/us/app/obd2-torque-obdii-check-car/id1359567217
I hope this helps.
There aren't any ODB2 apps for iOS that have a Carplay component unfortunately. Unless I'm mistaken. So you can have the iPhone showing the app, but you can't display it on the infotainment screen.
RudeJelly
Maryville, TN
2013 Civic, 2017 Civic, 2002 Ranger
I wonder if you could use an old phone and have it be in a permanent mount? I have several old iPhones laying around. I occasionally re-use an old iPhone as a dedicated app-runner. No sim card or activation required. I think you'd just mate it to the OBD adapter. It might fit perfectly in the cubby?
GPSMan
Many
Tip: in the little side cubby to the side of the screen you can attach a suction cup phone mount to the SIDE of the cubby. (The floor of the cubby was too small.)
Geep
Paul
SK Canada
2022 Ford Maverick XLT luxury hybrid
Te
I hope this helps.
tell us more about casting from your iPhone to the ”screen”. You are talking about the 7”display right? Very curious about this
GPSMan
Many
Ummmm I think he had Android?
I can't do video or nav yet. My cord jack is toast on my iPhone. I can only do stuff wirelessly. Which surprisingly I can do everything without a cord. Even charge. Just can't do CarPlay. 👿
mamboman777
Josh
NRH, TX
Te
I'm using screen2auto on Motorola Android phone.
mamboman777
Josh
NRH, TX
Torque and Screen2Auto can do that on Android. I gave up trying to find something to work on iphone.
Yup! That's what worked. Installation of screen2ato was not easy, but it works.... No rooting
Hager
Jake
iowa
Jeep
I use an obd2 adapter with torque pro to get this info. The Android adapter was $12 and the app was $5
I hope this helps.
I had one of the cheap Bluetooth obd2 adapter plug in on a road trip so I could monitor my engine temp and it fried my ecm.
mamboman777
Josh
NRH, TX
Good point. It drained the battery when I left out in one night.
wax87
Stuart
Dallas South
2004 Avalon
jsus
2022 Ford Escape Hybrid AWD
Is this true?
Looks like that iOS app is a scam intended to profit off the Torque name from the Android app which is well-known and seems to be decent. The iOS imposter doesn't seem to be any good.
The developer listed is different so it's not the same thing at all.
Looks like if you want to use Torque, you'll need an Android device; can't do it with an iPhone.
rivermaverick
Fort Mohave AZ
Does anyone know what the AC compressor supply voltage is? It has 2 wire high voltage connection so it's not 3-phase. I know it doesn't matter - I'm just curious :unsure: .
GPSMan
Many
Almost certainly full battery voltage.
It likely has an inverter and literally drives the compressor with Alternating Current. I can't get the shop drawings to open on my phone. The files are big. But thats my assumption. 220 volts.
