GAS TANK REMOVAL
Aquaman14
Cali
23 Maverick Lariat
Has anyone removed their gas tank? If so were the bolts hard to remove?
MetalsGeek
Rough
Torrance, CA 90503
Down to just the Mav
I have no idea about the specific fasteners used for the fuel tank, but you should be aware that Ford uses "Torx Plus" hardware, not legacy Torx. It's possible to bugger up the bolt heads by using an ordinary Torx bit in a Torx Plus fastener because the fit is too loose.
WhiteMaverick12
Andrew
Tennessee
2022 Maverick XL, AWD
I don't know why Ford put a gas tank on the truck. We all know they can run without it. I agree with you about taking it off and reducing the weight so it can get better fuel economy.
Wait....
bbhaag
@Aquaman14 Here are the general fuel tank removal instructions provided in the service manual. Keep in mind there are other steps that are also needed like fuel tank filler pipe removal and several sensors that need disconnected before the tank can be dropped.
Hope this helps.
Ford Maverick GAS TANK REMOVAL fuel tank1
Ford Maverick GAS TANK REMOVAL fuel tank2
Ford Maverick GAS TANK REMOVAL fuel tank3
Ford Maverick GAS TANK REMOVAL fuel tank4
Ford Maverick GAS TANK REMOVAL fuel tank5
Ford Maverick GAS TANK REMOVAL fuel tank6
Ford Maverick GAS TANK REMOVAL fuel tank7
Ford Maverick GAS TANK REMOVAL fuel tank8
djw479
'23 Mav Lariat Lux / '90 ZR-1 / '03 Yamaha V-Max
I guesses on why needing to remove the gas tank:
- Was cleaning the DIY spray-in liner out of the front bed threads and hit the gas tank (ala Ford assembly line on some 2022 Mavs).
- Seriously whacked the gas tank while off-roading or hit debris in the road?
- Wants to install a 30gal tank so they can travel further for cheaper gas 2 states over.
- Filled the "gas" tank with diesel (I mean it is a truck, right?)
Until the OP sets the record straight we can guess what happened. What's some other ideas?
My42waffles
Kegan
21 f150 powerboost lariat 20 fusion titanium hybri
Until the OP sets the record straight we can have fun guessing what happened. What's some other ideas?
There’s a 30 gallon tank option out there for upgrade???? Would it fit a tremor?
Aquaman14
Cali
23 Maverick Lariat
You guys are some comedians🤣🤣🤣. I made a bone head move and drilled a hole in the top of the tank. I was reading that the bolts can be very hard to remove and even break because of the Loctite that's applied. I'm hoping they're not Torx bolts like someone mentioned.
GPSMan
Many
He better be measuring the real internal capacity to prove or disprove GPSMan's theories once and for all! :LOL:
That's what I was thinking, but I don't have theories, I have photos. 😎
GPSMan
Many
Squirt some "FlexSeal" in the hole.
No really. Do it.
They also make gasoline proof JB Weld.
lajlmt
Lance
Rio Rancho
‘23 Maverick XLT LUX
I bought a Torx plus set to up in my tailgate assist, not thinking it was necessary, just the plus caught my eye, lucky…
