FWD HYBRID
Outdoors_Jared
Jared
Minnesota
2022 XLT Ford Maverick
Concerning this, Looking for a friend..... i am going to put 75lb sandbags in the bed of my maverick. Im thinking probably 4-6. I would like to add some weight to help get some traction, or grip on some tough spots where i live that is completely snow covered. Now i know its crazy, but i also ordered A/T BF goodrich Trail Terrain tires for my hybrid as well. What are your thoughts on sandbags to help add weight to the back?
710-oil-614
Cal
2025 Hybrid AWD Lariat
You could actually negatively impact the performance by loading up the the rear and taking weight off of the drive (front) wheel(s).
I would only recommend adding mild weight to AWD if that.
upnash
Ohio
Saturn Vue, Dodge Grand Caravan
Or you could try it if your problem is fish tailing in the snow. It might give more friction between the back tires and the road surface. If it doesn’t help then Oh we’ll you tried:)
Mightybeast
Adam
Oklahoma
Maverick hybrid
It sounds like reverse thinking. It is not a 4 wheel drive. Not even AWC. Put some Extra weight. On the passenger seat floor. Or you can shut down wheel traction control.
Jatrax
PNW
2023 VW ID.4
My dad always said the most helpless vehicle on earth is a two wheel drive pickup with no weight in the bed. No weight on the drive wheels means poor traction when its slippery.
But that is for rear wheel drive. As has been well noted above adding weight to the rear of a FWD truck will either do nothing or possibly reduce your traction.
Now if you really want to improve traction you could either get a good set of snow tires or pile those sandbags on the hood to increase the weight on the front axle.
(OK, the sandbags on the hood is a joke in case you missed it. Please don't do that.)
Outdoors_Jared
Outdoors_Jared
Jared
Minnesota
I can't help but render my brain useless, I have never driven either a FWD or RWD car. Nor am I a car geek. Thanks for the responses. I also appreciate the counter-intuitive comments as well. Makes me feel even more like a no brain. Any who, I most likely won't buy the bags then. I've always driven a AWD.
Jatrax
PNW
2023 VW ID.4
I remember when AWD was the new gimmick............ I feel old.
All fun aside those sandbags are not useless. Lots of people toss a couple in the trunk so they have some sand to throw on the ice if they need it. I don't think they will help you weight-wise like you thought but still not a completely bad idea.
Outdoors_Jared
Outdoors_Jared
Jared
Minnesota
Lol yeah that is probably the best use for the sand is to get "unstuck" i suppose. I didnt think of that, but yeah i guess i just posted to see if i should or not to buy them to add weight. Good thing i did, so my brain was doing its job i suppose for posting. :ROFLMAO:
Timothyd
Don't bother, it's counterproductive.
The tires are a good idea.
OpieGoneBad
Pennsylvania
2022 Maverick XL Hybrid, 2023 Maverick XL Hybrid
No need for weight in the bed as it is front wheel drive. The engine weight is over the drive wheels.
23MAVLariatAWD
VA
RECEIVED '23 Hybrid Lariat Mav Oxford White BAP
Michelin Cross Climate 2 tires they're top rated for snow and rain -- had them before they're awesome tires. Checkout consumer reports mag- April'22
TonyS
Tony
2022 Ford Maverick XL
Actually, a couple of bags of sand or gravel in a vehicle - regardless of type of vehicle or drive wheel system - is is a good idea in areas that get a fair amount of snow or ice. Not for weight. But to throw under and in front of the tires in case you get stuck.
I was surprised - when I looked it up - that Minnesota doesn't allow studded snow tires in winter months. So a few bags of gravel or sand along with a shovel seem wise to keep in the bed. And it's a pickup truck rated for 1500 pounds. 200-400 pounds in the bed isn't affecting anything as far as handling or traction - except maybe making it ride a bit smoother.
