Putting weight in the bed helps FWD traction?
Equipenquin
Benji
OH
f150
Do anything for FWD? Does it help with traction?
DavidS
Missouri
2011 Kia Forte
It shouldn't make much difference one way or the other. The weight of the engine being over the drive axle helps with traction. If you put a lot of weight in the bed, it could hurt you traction. But overall, it should handle like a FWD crossover or FWD sedan.
kingranchero
Dearborn
www.ford.com
2023 Ford Maverick Tremor
Yes and no, it depends what scenario you look at (and assuming you mean for inclement weather). Let us say you throw 250 lbs in the bed. Due to the weight transfer across the axles, the front tires will actually see less weight, to the tune of 5-10 lbs per tire. So taking off from a standstill could be slightly worse, as your driven wheels have less force normal and thus less grip on the road.
When coming to a stop, I think your front tires will see more grip due to the higher vehicle weight as the body pitches and transfer weight forward. However, the tires will have to work harder to stop due to the overall higher weight. For ~250 lbs it is probably a wash.
Where I think you would see a benefit is in turning. The rear tires will each see an extra ~130 lbs and thus have more grip. That extra grip could keep you from oversteering if you take a turn too fast. Unexpected oversteer in snow can easily put you into a ditch, or swap ends on the road. Probably not super likely, however, as in a FWD unibody vehicle you'll usually start understeering if you take a turn too fast on snow. Oversteer is more likely to happen if you're turning and a rear tire hits a slippery patch.
All that analysis aside, if you plan on driving in snow/ice a few months every year your best bet by far is a set of good winter tires.
goyogi
Tesla Model S
SgtLip
Donald
Disney World
