jdmz
Denver, CO
Ford Maverick XLT
How do you like the subwoofer? I don't need a ton of bass.. I was happy with the rockville spare tire subwoofer that I put in my Toyota Prius.
I am looking to do the same exact upgrade to my XLT non B&O. The stock speakers sound horrible.
bckrupps
Jeremiah
Fort Worth
2022 Ford Maverick XLT
I did the speaker upgrade with Infinity Reference bought on Amazon for $99 that included 2-6.5” REF-6532IX & 2-4” x 6” REF-6432CFX and it was an amazing upgrade in clarity of sound. Had to turn the average volume down because of the efficiency of the Infinity speakers. But, when I added the Puzu PZ-C7 DSP Amp , the sound came alive in areas that I've never heard on music that I'm intimately familiar. Once again, the average volume was turned down, but the clarity of the sound increased tremendously.
Best of all about the Infinity speakers is the grill that comes with the 6.5" in the front has the Infinity logo that can be removed and put in the little indentation on the front of the Maverick speaker grill. I painted a couple of flat 2032 batteries flat black and glued the logo on them, then glued the perfectly fitting batteries into the logo indention on the stock speaker grill. It looks pretty good.
I do have a Rockville RW68CA mounted but not connected tot he DSP yet, nor powered which I will do. Had I to do it over, I would not have added the sub because the sound I have now is perfect for me.
I bought the Puzu DSP Amp for $135 from eBay seller cybereveryday. What convinced me to purchase this is that it include the harness for a true plug and play installation for the DSP Amp. Initially I got the wrong Ford harness but the seller was great to work with me and get the right harness for the Maverick. This little 45W RMS DSP Amp made the music come alive for me in my XL and was well worth the $135.00.
Anyway, do what you think best for you. Best to all!:cool:
I finished mine last weekend. Same setup. That Puzu amp makes such a difference. When I first customized it I had no idea how to customize a DSP and it was terrible. I watched a couple videos and readjusted pretty much the opposite of what I did the first time and it’s pretty outstanding. I will still add the Rockville in the spring. One thing I have noticed that is frustrating is the variances of volume output depending on the input. It kind of forces you to set levels higher than needed. For instance on a usb stick the Puzu can clip or bottom out the speakers on some songs at 16 or so but using CarPlay you might need to hit a middle 20 volume to get good power and volume. Usually I just lower the bass on the stock eq if needed below the middle line. It’s not easy to find a great balance for everything. The power is definitely there though. It’s enough to get what you can out of those speakers especially considering the quality of the Mavericks interior.
uh50
Howard
www.hchaney.com
2022 Maverick XL, VB, 2.0 EB
Glad you are getting more out of your system. I don't use mine at a 16-20 volume since installing the DSP Amp and I've not experienced any bottom end clipping. I do notice that the input choice does affect volume somewhat. The FM and Satelite inputs are the loudest and the USB is slightly below, but it's not enough to be worrisome for me.
Again, glad you like the sound out of the system you installed.
Jgonzo
Jonathan
Maryville, TN
Maverick XL
Would you mind sharing which videos you used in order to tune the DSP?
I also just installed the Puzu DSP but I’m a complete novice on audio tuning.
Did you use a Real Time Analyzer or a separate microphone/SPL meter?
Thanks!
uh50
Howard
www.hchaney.com
Thanks!
I did not use a video. I just hooked up my computer, ran the software, and adjusted available settings to my taste. With the computer, I was able to save various setups, then compare them. A Real Time Analyzer or mic w/ SPL meter does not hear for me. I didn't try to automate the setup process. Sorry I couldn't be more help with this.
jcgaskil
Allen, Texas
Maverick XLT FX4 (Alto Blue)
Jeremiah. Did you use front door component speakers? I just bought the Focals with separate tweeter and crossover and ordered the PUZU. Since Ford is running full range to the doors and tweeters, I'm wondering if the PUZU can be used to act as a crossover to separate the frequencies between door and tweeter.
You reference videos you used to adjust the dsp. Please share as I am also a newbie to DSPs.
Also - what harness did your purchase? PUZU is telling me to get the one for "2018 and later Ford Ecosport"
Thank you
uh50
Howard
www.hchaney.com
Thank you
I know you didn't ask me for the info, but just in case you still need, here is a photo of the Puzu Ford Harness for the Maverick and the one I installed. Absolutely the easiest part of my audio install. I sent my supplier these photos so there would be no mistake.
Ford Maverick Full audio upgrade complete Screen Shot 2022-10-13 at 4.39.52 PM
Ford Maverick Full audio upgrade complete Screen Shot 2022-10-13 at 4.41.11 PM
Ford Maverick Full audio upgrade complete Screen Shot 2022-10-13 at 4.41.32 PM
Additionally, here are four links that show some tuning. Can't vouch for them, but they were all I could find that were in English. There is a factory video that is not in English.
BMW F10 Puzu DSP Amp Tuning
PUZU PZ-C7 Plug & Play DSP Amp (PZ-C7-TOYOTA ) with Tuning Software Review (Scion tC2 _ tC2.5)
Car DSP One-Seat Tuning (DSP Tuning Series - Episode 1)
How to use car DSP amplifier and android app car radio to upgrade digital audio signal processor
Good Luck...:cool:
jcgaskil
Allen, Texas
Good Luck...:cool:
Thank you. I will give these a try!
jdmz
Denver, CO
Ford Maverick XLT
If anyone is curious, here is a picture of the focal RSE-165 crossover. I'm going to wrap electrical tape around it to make it smaller and try to fit it under the dash where the tweeters are to block out the bass.
I traced out the circuit and the woofer side of the crossover just goes straight through. The tweeter is in series with the capacitor and parallel with the black resistor/inductor?.
Ford Maverick Full audio upgrade complete 20231228_090329
hemming1
Brad
Washington, IL
2023 Ford Maverick XLT
Did you install the RSE-165 crossover unit? If so, did you have to splice into the factory wiring?
HushCarAudio
Gold Sponsor
Bruce
Aubrey TX
I hope you guys know I'm the audio forum vendor here and can build you custom harnesses. Let me know if interested. I've been making them for the F150 guys for over 8 years now.
hemming1
Brad
Washington, IL
@jdmz I figured out what you were saying with the passive crossover only being active for the tweeter lead wire. I unsoldered the woofer lead wire and soldered it to the input side to reuse the connectors. I also purchased this speaker harness to plug into the factor tweeter lead. I have the glove box and fuse box panel all opened up, so I'm planning on just fixing the crossover somewhere in there.
Ford Maverick Full audio upgrade complete PXL_20240216_233129514
Ford Maverick Full audio upgrade complete PXL_20240217_020457794
Focal RSE-165 Tweeters Installed
Ford Maverick Full audio upgrade complete PXL_20240217_000140304.MP
Ford Maverick Full audio upgrade complete PXL_20240217_000133579
Ford Maverick Full audio upgrade complete PXL_20240217_021517839
jdmz
Denver, CO
Ford Maverick XLT
Same here. The crossover fits perfectly under the stock tweeter location if you remove the plastic case and just wrap it with duct tape. Cheers!
JBONE
Bay Area California
2024 Maverick XLT Hybrid
Thanks for the great thread all. I tried the Focal RSE-165 speaker upgrade with stock head unit and wound up returning the speakers. There was no audible improvement with these speakers and in fact a decrease in base extension. Maybe the Focal mid bass was a bit tighter but the factory speakers have lower range for sure. The stock factory setup may not be great, but it is adequate for now as it is designed to optimize all components that are integrated. I may consider an amp and sub upgrade, but for now just the RSE speaker upgrade did not work for me.
Absolutely not.
You almost certainly had something installed wrong. Probably out of phase or shorted to ground.
If you haven't returned the speakers yet, I would suggest opening a new thread with some pics and asking for help.
