**Sneak Peak** Full Plug and Play Audio Upgrade System
Rynobuilt
swmo
2025 lobo
As the title says, here is a sneak peak at the newly designed and engineered full plug and play audio system from MB Quart. Coming later this year.
New replacement door speakers, dahs tweeters, rear pillar speakers, 5 channel amp with its own mounting plate, full plug and play harness, will fit both B&O and std systems, Eco boost for Hybrid trucks, 1-2 10" ported subs, depending on if your hybrid or not, or if you just want the 1 sub, harness has 2 leads if desired.
This system is impressive! sounds SO much better then stock set up.
Installed in my 2025 Lobo.
Ford Maverick **Sneak Peak** Full Plug and Play Audio Upgrade System IMG_2121
Ford Maverick **Sneak Peak** Full Plug and Play Audio Upgrade System IMG_2139
Ford Maverick **Sneak Peak** Full Plug and Play Audio Upgrade System IMG_2143
Ford Maverick **Sneak Peak** Full Plug and Play Audio Upgrade System IMG_2132
ScottyC
Central NY
2025 Ford Maverick AWD hybrid
Looks sweet!!
Parabellum
2015 F-150 & 2025 Maverick XLT
Did they give you an estimated cost?
asylus
George
TEXAS
'24 Ford Maverick Lariat Tremor
looks interesting. I want a good equalizer set up at some point.
BLUEOVALRACER
Ravenna,Ohio
2025 Maverick XLT AWD
That looks and I bet it sounds cool but I use that storage under the seat when I go shopping and use it for Gallon Water Jugs or 12 packs of Sweet Tea!!
Rynobuilt
swmo
2025 lobo
you can still us ether one side! thats a lot of water or tea!
Ryom
PA
2025 Maverick Lariat 4K BAP Eruption Green
Hybrids have a 12v battery on the other side, so sub boxes that fit underseat tend to negate much of the utility of that.
SuperTux
2023 XLT
Can you provide any info on the ported sub and box configuration? Power handling, impedance options, tuned frequency...
chilicharger
NM
'25 VB Lariat hybrid 4k tow
Is there an option for a sub delete? I dont need a lot of thump and dont want to lose the storage. A small sub behind the rear seat is all I need.
I second this. I can't lose my underseat storage, especially since I only have the driver side due to having a hybrid. Please develop a sub solution that mounts behind the rear seat. There is plenty of room. Not enough room for a big box, but enough for those standalone powered subs. That should allow you to go cheaper and smaller on the main amplifier, too.
Cancunbadlands
Cancun
Cancun
I bet it's gonna cost a lot of #dough
Parabellum
I’d be interested in just the speakers. I don’t care about bass what so ever. A subless option would be solid
