Fuel pump shuts off while pumping gas.
Jonny44
Jon
Minnesota
2025 Mav hybrid AWD XLT, 2016 Ford Escape Titanium
Check your filler pipe for a clog in the vent line (small tube attached to the filler pipe). Common for insect intrusion.
Ford Maverick Fuel pump shuts off while pumping gas. 1780675980875-ka
If you are standing out of your door where it's quiet enough - can you hit the fuel release and hear a sound back by the tank area?
Relay is getting thrown to release the pressure just before the door pops - or it should.
Maybe that didn't happen once.
But seems odd a sensor didn't pickup on that, and refuse to open the door.
Or sensor is bad, or relay, or valve.
Seems posters have shared their pics when some of those happen - indeed a dashboard light/warning goes off.
Johnkn
MD
Try a different pump at a different station....
Tried filling up twice. Pump shuts off every few seconds, spits gas out. Takes forever to fill. After the 2nd fill, the check engine light came on. Maverick 2023 hybrid.
Don't stick filler nozzle in quite as far. If you hold the pump handle too high up it will restrict the flow and pump will shut off. Also try setting the pump retainer setting to the lower speed.
