Ford Pass Remote Start Problem 2025 XLT
Yeah, I set up the hotspot a few days ago and created a trial account with AT&T. I'm in Canada so we don't have AT&T, but after the trial they apparently will hand me off to Bell. In any case, the hotspot was working a few days ago and now it isn't.
Vehicle hotspot menu showed full bars of 5G, so the modem can see a cellular network. My cellphone was able to see and get DHCP/IP from the vehicle's wifi router, but it couldn't get an internet connection.
So maybe the hardware is fine, but Ford has an issue with their cellular provider.
Maybe the trial is also physically handed off and roaming data is not activated,??? Or?
ETA: If you are using your phone as hot spot wouldn't you be using your cellular data?
ETA: If so do you have data roaming activated on your cell phone??
semicolin
Colin
Ontario, Canada
2025 Maverick XL
Entirely possible, although well above my pay grade to be able to repair it.
semicolin
Colin
Ontario, Canada
2025 Maverick XL
Vehicle hotspot is a router in the vehicle that allows cellphones/tablets in the vehicle to access the internet via the vehicle's modem. It has nothing to do with the data on your own cellphone at all.
Nope, that was truck as hotspot from description of truck giving cellular strength.
Just like at home (except Apple usually), you can connect to your wifi even if the internet in general is out.
jjk
Jean
sammamish
Maverick 2025 XLT
I also have an XLT 2025, got it on Jan 22, 2025. I was able to connect fine until this morning, which led me to this forum. I tried everything recommended here, except a cellular modem reset, and nothing worked. I contacted the dealership where I bought the car and they told me Ford is aware of the issue and will be providing a SW update. I don't know when. Make sure the car is setup to receive updates and connect it to your home WiFi.
tried again this morning after waiting 12 hours and it successfully connected. Would be good to hear from Ford if there was an outage that was addressed. I had left the vehicle in the driveway connected to my home Wi-Fi hoping for a software update, but none was received, at least according to the update history. We will see how long this will last.
semicolin
Colin
Ontario, Canada
2025 Maverick XL
And we’re back in business! Random thirty hour outage.m, but at least now it’s solved.
tkammen270
NNJ
2025 Ranger Raptor
I’m having trouble remote starting via the FordPass app on my 25 Lariat. It started last night when I went to start the truck.
It usually takes less than 20 seconds to start but now it looks like it’s going to start for about 30 seconds then goes back to the normal screen. Oh and I just noticed my miles and fuel percentage aren’t updating and says the truck is parked when I clearly drove it. Oh boy.
LibDan
Dan
Columbia, SC
Eruption Green 2025 Ford Maverick Lariat Hybrid | 4K Tow
Sounds like what the rest of us have been experiencing. I note you have an Ecoboost, is that the truck you are talking about? I only ask because there has been a suggestion that this problem happens to people with hybrids. The good news is that is seems to come back again after a few days (but can go away again too).
tkammen270
NNJ
2025 Ranger Raptor
I do have an Ecoboost. The last location update in the app was 19 hours ago. I guess that's when it stopped working.
Toddman45
Todd
St. Louis, MO
There was a update for Ford pass last night, I don't know if it's a fix for the 25s. but, I do know it removes the need to have a pin on your smartwatch to use the Ford pass app.
I would expect it to be more related to lower priority data restriction during high usage times just like my TV streaming router.
Desiree
Desiree
Indiana
2025 Maverick
RE:#2. Sit in truck, push start, may want to uncheck 30 minutes max idle time, leave mode in Park, set the EBrake, get out with fob, shut door, double lock with fob or door ribs or keypad, don't forget truck is running!
I tried to start then lock the door and leave with the key fob but It won't keep the door locked. As soon as I am out of range, it unlocks the door saying no key present. I haven't tried leaving the key inside and locking, then using the 2nd key to unlock.
Desiree
Desiree
Indiana
2025 Maverick
I uninstalled and reinstalled the Ford Pass app this morning and it started working again. We will see how long it lasts.
Did you press the lock button TWICE WITH A 0.5-1.0 SECOND PAUSE? (Aka double lock). You have to lock it with fob outside of truck and door shut.
tkammen270
NNJ
2025 Ranger Raptor
Just tried that and no luck.
