Headbanger
Ron
Finleyville PA
2023 Maverick Hybrid Lariat
Just wanted to post another experience using a tow dolly for those considering one. Towed the truck just over 1300 miles on an ACME dolly with surge brakes.
Aside from checking and adjusting the straps, everything went well. On the dolly side, I did have both strap hooks on one side come completely off, twice. I have no idea how it happened and have purchased enclosed D rings to prevent that from reoccurring. The wheels also make a crazy noise like the brakes were stuck on, however the brake dust was minimal on both wheels and it went away after a while.
On the truck side, I did get the crazy warning messages like others have mentioned, however after a short drive, they went away. No additional problems whatsoever.
I'm still on the fence about the dolly as it's pretty heavy to move around by hand. I'm pushing retirement age and aren't as strong as I used to be. Also, the dolly is very wide with not a lot of room for error. If it weren't for the easy driving Sprinter van, I probably would have fought to keep it centered, leading to a miserable trip. I have another trip planned this year but may move to flat towing next year.
Anyway, hope this helps.
Here's my setup..
Ford Maverick First trip towing Maverick on a tow dolly 2024-06-06_18-13-13_641
BradnChristine
Brad
Wyoming
Here's my setup..
Once you try Flat-towing, you'll never go back.
Dad
The hybrid was made to flat tow. Initial expense with the baseplate (I recommend Demco), braking system and bar, but beats the inconvenience of what to do with the dolly.
Xbbqpitmaster
Full Time Gypsy
2024 Ford Maverick XLT
bgn
WA
Headbanger
Headbanger
Ron
Finleyville PA
Appreciate the feedback. I'll check into that hand dolly, it looks like it would do the job for sure.
TopDawg
Randy
Lexington, SC
2012 Ford F250 Lariat 2WD 6.7
Have over 30k using dolly behind 32' class C. 2.0 EB. No issues after initial lesson oon turning off auto brake lock. Keeps mileage off front drive. Can't flat tow EB. I'm 76 y.o., the trailer dolly is a good idea, thanks.
MavUnicorn
Kevin
2024 Maverick EcoBoost XL
Do you mean turning off the brake hold button on the console?
TopDawg
Randy
Lexington, SC
Yes. Once you're on the dolly, place in park and deoress the brake lock prior to turning engine off.
shadow76
bob
TX
F150, Ranger
Here's my setup..
What procedure did you use to prepare the Maverick for dolly towing?
Headbanger
Headbanger
Ron
Finleyville PA
Nothing really. Drove it onto the dolly, put it in park, made sure the e-brake was off, and shut it down. I might try to put it into towing mode to see if it makes a difference with all the lights when it’s time to back off, however I don’t think that’ll matter.
shadow76
bob
TX
F150, Ranger
Dolly towing is best for my purpose as the option exists to tow different vehicles depending upon the final destination. Furthermore, no issues with auxiliary lighting or braking systems as the dolly is so equipped .
Additionally a friend has used the dolly to transport several classic vehicles after a purchase. These are usually fun trips to accompany him.
