Engine cover for 2.5L Hybrid Maverick?
Guv
Ford
Could you use it for a pre-heated snack/pizza tray:unsure:
wax87
Stuart
Dallas South
2004 Avalon
This 2.5L hybrid engine cover part number (LX6Z-6A949-B) was mentioned in the thread about ecoboost engine cover, but a Ford Escape thread (URL listed below) gives much more detail. That Escape thread also shows the other three part numbers needed for the complete installation along with photos (see tiny green circles) of where the threaded studs go on the engine. I think most people would say this has no value other than under hood aesthetics, (I agree, but I still want one). Has anyone tried to install one of these yet?
www.fordescape.org/threads/2020-hybrid-engine-cover-parts.117653/
can you paint the grove or Ford logo the same color as your truck?
PDM33
Phil
NE Ohio
2022 Maverick Lariat Hybrid
Probably could with heat resistant paint meant for plastic.
It's made out of some sort of foam rubber rather than plastic. So you may want to test somewhere innocuous like the underside first just in case it's more solvent sensitive.
Michaelkov
Michael
Atlanta, GA
2021 BMW X1, 2018 Toyota Rav4, 2022 Ford Maverick
TheShark
2024 Maverick Lariat Tremor, 2023 Bronco Wildtrak
Installed the engine cover today, really easy install. That's to the guys in the forum who supplied part numbers. I think it dresses up the engine compartment.
Ford Maverick Engine cover for 2.5L Hybrid Maverick? 46F28573-840F-44DB-85CE-C1789310ACBF_1_105_c
Steve2u
Ranburne alabama
Ford maverick xlt
Where did you get your cover at and how bolt did it take thanks
PDM33
Phil
NE Ohio
Might just be me but when there is a recall about too much heat in the engine bay the last thing I would think about doing is putting a cover over the hot engine šŸ”„. Ford didn't put it there for a reason right?
STUFF2C
j
fl
bunch
they saved a few dollars here and there... that's the biggest reason
Wnbasac
Louie
Calif
Honda CR-V & firebird T/A
I canā€™t find the cover via fords parts.com? I canā€™t get it to search fords entire data base, only by specific locations . What year ,model , fords had this cover so i can search wrecking yardsā€¦tks
Don806
Don
SE Ohio
2022 Ford Maverick XLT, Also a 2000 F150
I can find it NOWHERE in the country. Iā€™ve been told itā€™s 18-19-20 escape hybrid
ā˜¹. I have a line on one, but itā€™s on a used car for sale on a lot, might have to schedule a test drive šŸ˜‚
