Except with a (non-plug-in) hybrid ideally we want the power staying in the small battery for driving rather than using it to heat coolant. So running the ICE early in the drive cycle is sort of a 'have your cake and eat it' because you get to 1) generate motive power 2) charge the battery 3) capture its waste heat for HVAC/battery and 4) warm the catalyst to operating temp which is inevitably needed.I don't know how you guys think electric is "super inefficient." It's physics; the heater element is a resistor. ALL the power dissipated becomes heat. Now the only question is how efficiently you get that heat to the desired location.
Or if it's an EV that doesn't have an ICE then even more efficient than just resistive heating is using a heat pump. Oh boy does the EV crowd love heat pumps.
