DIY Forscan enabled Cruise control XL models only
Snax
North America
To answer @TobyGadd's original question mine which is an XL with a 2.0L ecoboost engine is set to xxxx-xxxx-xx72. I tried xxxx-xxxx-xx73 and it threw a checksum error. I'll update main posted accordingly to make note of that difference.
Yeah, my typo threw this for a bit of a loop. But once I realized that the checksum wasn't right, I went back to figure out why. Took me a bit to figure out what happened. I guess that why checksums exist. ;)
Thanks for updating the original post. I wish that other threads on adding cruise control would clean things up as well, since there is a LOT of misinformation out there. But at least this one is solid--especially the ABS update.
Automate
Atlanta GA, USA (ATL)
Fusion Hybrid, Mav XL Hybrid
I don't know where you came up with this but I can say on the 4k tow package there is no TBC module and mine has a factory installed electric brake.
I don't have a Mav yet and only found two post of FORScan connection logs to go by. The TBC was a guess. Please post your FORScan connection log and I will update the table.
Maverick2022XL
name
hinterlands
Thanks for verifying and testing my discovery. While it might not be immediately apparent what the difference(s) may be, I suspect that Ford didn't arbitrarily make two settings for the same function.
@Maverick2022XL, you might want to update your post to reflect these new findings?
All the first 6 digits in the code don't necessarily correspond to one setting. Some XX are A and B, A or B, A only, B only, etc. the xxxx-xxx0-xxxx and xxxx-xxx1-xxxx may not correspond to cruise control but it does to something. Without Ford's official documentation or possibly their IDS software it is all trial and error along which one of these kid's is not doing their own thing .
Maverick2022XL
name
hinterlands
No need you have all the modules covered for an XL including what is needed for the 4K and Copilot 360 package.
Automate
OK, so does FORSCan call the 4K trailer brake module TrlrBM instead of TBC? Thanks.
Maverick2022XL
name
hinterlands
I'll be nice and save you some time.
Look under the module list then go cross reference the module register addresses against specific builds using VIN numbers at
https://www.motorcraftservice.com/AsBuilt
Not all those modules will be used on Mavericks. This is the way to whittle down that list into your own spreadsheet. There may also be a module or 2 on the Mavericks that aren't on the F150 list.
Snax
North America
Now, we just need to figure out what BCM 726-16-03 is for. Different on hybrid XLT than hybrid XL. Seems unique to Maverick?
Maverick2022XL
name
hinterlands
One module for sure that is on Mavericks that is not on F150s is the AWD aka all wheel drive module that one is at module address 703.
Another one that differs is the BECM. The non hybrid battery control module on Mavericks is called a BECMB instead and is at module address 723. Then there is the battery control module related to the electric portion of hybrid trucks that is not on the F150 list.
Maverick2022XL
name
hinterlands
Why and to what ends is that needed for cruise control?
Snax
North America
I came across it while working on cruise control for my hybrid. It could be associated, but I can’t tell. Any ideas?
RookieBlue7
Georgia
Maverick XL
Does anyone have a set of the switches or know a parts counter that either does or is willing to order it for me? My local dealer won’t place the order because the 8576 switch is backordered
Bushpilot
Greg
Spokane, WA
Chevy Volt
Try Superior Ford Parts, that's where I got mine.
Part Number​
Part Name​
Price​
Quantity​
Total​
SW-8579-​
Switch Assembly - Control​
$19.19​
1​
$19.19​
SW-8576-​
$53.36​
1​
$53.36​
Subtotal: $72.55​
Estimated Shipping to 99006 via Economy Shipping: $5.19​
Total: $77.74​
RookieBlue7
Georgia
Maverick XL
Part Number​
Part Name​
Price​
Quantity​
Total​
SW-8579-​
$19.19​
1​
$19.19​
SW-8576-​
$53.36​
1​
$53.36​
Subtotal: $72.55​
Total: $77.74​
I’ve placed an order. Hopefully it doesn’t get cancelled like one I’d placed at another dealer’s parts website.
RookieBlue7
Georgia
Maverick XL
So they took my money and cancelled the order. Said they’ll refund me in a few days
Maverick2022XL
name
hinterlands
I bought my switches new at
https://parts.ford.com
It shouldn't matter what dealer you pick since the part ships from parts.ford not the dealer picked.
