scottjl
Midwest USA
'25 Lariat Eruption Green, 4k, BAP
Not my original idea, saw a photo of it elsewhere and decided to build my own. Sharing my build instructions after someone else asked me for them. Lots of room for tweaking. Gotta love the FlexBed! Total time, about a hour for me with table saw and power tools.
Updated photos: attached 4 brackets, opposite positions so I have options for hooking bags, bungee cords, etc.
Some weren't aware, but Ford supports things like this. For more ideas check out the FLEXBED web page.
Materials:
  • Two 2x4" 6' or longer pieces of wood
  • 6-20+ 6" deck screws
Tools:
  • Screwdriver (hand, power)
  • Saw (hand, power)
  • Drill (Pilot holes makes things easier)
Assembly:
  1. Cut two 54 1/8" pieces from the lengths, optional cut corners from one side of a length. I have a lined bed, for bare metal bed you might want to go slightly longer. Test that the long boards fit in and out easily before proceeding, you may need to trim a little off. Better to start longer and shorten as needed.
  2. Cut one, or more, 4" pieces from the remaining wood. I used 5 total.
  3. Place all the pieces flat, small pieces between the lengths. Put one piece at each end, then space rest along length as you desire.
  4. Drill pilot holes into edges of lengths where you will be putting spacer blocks.
  5. Screw from edges into the spacer pieces. You can get away with one screw but I used two from each side.
Optional:
  • Cut corners off edges to allow divider to rest against bed, or leave corners to have divider float 1/2" above bed.
  • Stain, paint, weather treat wood, or use treated wood.
  • Affix eye bolts or hooks along length of bar to affix bags, straps or other items to.
  • Add cut material, rubber, etc. to ends so they don't scrape sides of bed.
  • @k2rizzle pointed out some nice hooks that work well with this. https://a.co/d/ehdnsBF
  • Screw in feet (or similar) can go on bottom to lift from bed, or sides to adjust width to fit.
Emergency uses:
  • Fuel for fire. 🔥
  • Weapon. ⚔
  • Stakes for defense against vampires. 🧛‍♂️
Ford Maverick DIY Bed Divider img_8564
Ford Maverick DIY Bed Divider img_9450
Ford Maverick DIY Bed Divider img_9451
Joylove
2025 Ford Maverick Tremor
Ford Maverick DIY Bed Divider img_8567-
What are the seatbelt-looking things here? Retractable straps?
Hot Runr Guy
West Chicago, IL
So my OCD is wondering, why isn't the middle block centered?
Sorry, HRG
scottjl
scottjl
Midwest USA
Sorry, HRG
Hmm, yeah, might be a little off. Offsets the weight distribution of the rear license plate being on the passenger side.
That's my excuse and I'm sticking to it!
Sginn
steve
Scottsboro
Mine wouldn’t work because I have Tonneau cover. The double stack 2x6 wouldn’t slide in. I just put one 2x6 on top of other. Same result, just not as pretty. Good job! My hard cover is a Rough Country.
lm126027
Larry
Central MA
2024 EB
Looks great, but can't put any kind of divider in my Mav as I have the Ford storage box on the left side.
MrPnut
Wake Forest NC
2022 XLT
Materials:
Tools:
  • Screwdriver
  • Saw (hand, power)
Assembly:
Optional:
  • Add cut material, rubber, etc. to ends so they don't scrape edges of bed.
Emergency uses:
  • Fuel for fire.
  • Weapon.
This looks great and you have skills that I don't. I installed a TMat system in the bed of my Mav and it works great for me and gives a little more flexibility to arranging stuff in the bed.
Ford Maverick DIY Bed Divider Tmat Start
Ford Maverick DIY Bed Divider Tmat finished
Ford Maverick DIY Bed Divider Tmat layout
That's a great system. I had never seen anything like that. 👍
lm126027
Larry
Central MA
2024 EB
Have the Ford rubber mat over my spray-in liner. Does help keep things from moving around somewhat. Though hard stops will still send stuff flying. lol
