blackb13
Based on the information below, do you reason that the yellow/green and black/blue wires would be used with the purple/white left alone? I
You're overthinking this. It's an LED light. Strip the wires back and start connecting them to power. When the light illuminates, you're done. It's not going to blow up if you connect it wrong, it just won't work. If you're paranoid, use a 9v battery to see which wires turn it on. Or if someone from that thread can test the wires for you, that would also work.
Polak658
RI
Scion xA
Lol ill start with the battery, thanks
kcamp317
Cincinnati, OH
'20 Ford Escape Titanium Hybrid 16 Ford Escape SE
Well this seems easy. My 23 XLT needs this. Thanks for the write up and DIY.
Tremor1
Ron
Maverick Tremor Lariat, Ram 1500, Audi RS4 Quattro
Braderick
Brad
High Point, NC
Bolt EV, RAV4 Prime, KИ EV6
Dr.Steve
dr. Steve Bruhle
Baltimore
22 Maverick Hybrid XLT
Wait, they removed ambient lighting in 2023?
Hardening2753
Ford Maverick Hybrid
Instead of ordering the factory part, I decided to just make my own ambient/console light.
Remove the lid (clips circled in green, other clips are hidden towards the back) and unplug the harness (red circle) that is used to illuminate the USB ports.
(picture credited to @Executech)
You'll tap into the white/stripe for your (-) ground and purple/stripe will be your 12v (+) positive - these will dim along with the dimmer switch on the dashboard. The yellow/stripe is switched 12v that can be used for some other low power accessory. Dash cam, etc...
I used an LED light along with a 1k ohm resistor, soldered them together, wired everything up with some spare 18ga and taped them up. Shrink tubing would also work, but I didn't have any and didn't want to go back to the store. I used a 3M Command Strip and mounted it where the factory light would've been (there's an outline in the molding).
Looks pretty good. I might purchase some more and do the footwells.
Thanks for the post!
TpaTruck
Guest
Thanks for posting, will look into doing this to my 23 XLT. Before reading the details though, how do you "Remove the lid"?
SteveM
Maryland USA
2018 Silverado, 2025 Eruption Green Lariat Hybrid
Is the resistor in series, or parallel with the light?
nicobonis
Nicolás
Banfield - Buenos Aires - Argentina
Ford Maverick Tremor 2025
Awesome Work, thanks for sharing,.
Ferdinand
I did exactly the same thing...they arrived today. One for the back seat area, and I'll pair an old USB 12v adapter and another = "USB atmosphere light" for the storage tray area...
This works for me. Easy to install on USB outlet, and really low cost (color choice and adjustable intensity):
Ford Maverick DIY - Adding ambient light(s) to 2023 Maverick XL/XLT for <$10 1674731255653
Ford Maverick DIY - Adding ambient light(s) to 2023 Maverick XL/XLT for <$10 1674731321023
Rivers90
Ben
XLT Tremor, Miata
Thank you for the links to get the parts.
I may up the resistor to lower the light level.
Does the color of this light match the other lights?
