- Jun 23, 2023
- Stanwood, WA
- Maverick
- Engine
- 2.0L EcoBoost
I had a VW that did this. It actually even varied the brightness of the light with how much you turned, not sure if this is that feature or it goes by turn signal on/off or how it works. It was a neat idea, but I never felt it did much compared to just having the lights on all the time with headlights. But with these DD fogs it may be more noticeable given that they seem to project much more light than I think OEM lights do.Looking through forscan and you can program the fogs to be used as turning lights as well. Like when you hit the turn signal (left or right) they will light up to help you see into the left or right turn. Thats if you are using the factory wiring harness like Vtech87pr set up to use on his application.
Just a thought. Maybe Antonio can try this out with his set up?
