Deep Sleep Mode - CURED!! Battery Replacement
Jmv0429
JV
Stamford, CT
2022 Maverick Lariat Hybrid
Do you get pinged by Ford Pass 2 minutes after each drive that your Maverick is in Deep Sleep Mode? Cabin lights don’t turn on when you get into car at night? Intelligent Access unlock doesn’t work on passenger side? … My CT dealer was able to finally fix this after 9 months with this persistent Deep Sleep Mode issue on my ‘22 Hybrid Lariat… here is the tech write up.. ask your dealer to perform these steps… my truck battery saver/deep sleep problems are GONE!
Ford Maverick Deep Sleep Mode - CURED!! Battery Replacement IMG_7820
Packer Bill
South Dakota
I am glad that your battery was replaced...which battery was installed (brand, capacity and type)? Most Mav owners have replaced their battery with an AGM battery, non-Ford brand and with a grater capacity.
Headbanger
Ron
Finleyville PA
2023 Maverick Hybrid Lariat
Glad to see that they resolved your problem! This is a big nusance for many of us hybrid owners. I keep mine in the garage and on a tender when not driving. So far, so good..
Thoron99
NC
2023 Maverick Hybrid XL
Haven’t had any deep sleep issues so far (almost a year old). But I also have all the connectivity stuff turned off, and uninstalled Ford Pass.
computerpulse
Edward
2023 Ford Maverick
I believe they have a recall out on this coming out this month because I have the same issue
computerpulse
Edward
2023 Ford Maverick
What’s the chance you can provide the full readout so I can read everything?
Jmv0429
JV
Stamford, CT
That is the full read out for that issue.. the next page is just multi point inspection notes
svogt302
NJ
Should have a higher capacity one
Original small battery: BXT99RT4A
Product Information
  • Warranty: 3 Year Limited Warranty
  • Unit of Measure: Each
  • UPC: # 31508666030
  • Battery Type: Standard Flooded
  • Height (in): 6-7/8 Inch
  • Length (in): 8-1/4 Inch
  • Width (in): 6-7/8 Inch
  • Terminal Type: Top Post
  • Weight (Lbs): 30 Lbs.
  • Voltage (V): 12 Volt
  • Cold Cranking Amps (CCA): 470 CCA
  • Cranking Amps (CA): 587.5 CA
  • Group Size (BCI): 99R
  • Reserve Capacity (min): 65 Minute
  • Positive Terminal Location: Top Right
Headbanger
Ron
Finleyville PA
It's a shame that you need to go through all of that, just to save your battery. I've seen posts where owners wrap their key fob in foil as well. So silly. Ford should replace batteries if that's what it takes. It shouldn't be up to us owners to figure out how to save battery life.
Oscarcat
Eric
Encinitas California
24 hybrid 3,500 miles = No deep sleep issues, I too deleted FordPass. Roughly 50% less clicking from the relays now.
The only "bad habit" my hybrid has, and my 22 EB had it too, is the driver's door randomly locks but all others remain unlocked. I am careful not to hit the lock lever by the interior door release lever when I exit.
Montana
Check back in after a couple months/year. I'm not convinced.
But as others have said, it's the trucks need to constantly communicate and using the app, so it would be awesome if you don't get it again. But it's likely you still will no matter how hard you try not to.
Thoron99
NC
Yeah it shouldn’t be an issue to begin with. Apparently a Ford thing not just the Maverick, I’ve seen some videos on YouTube where people were having battery drain problems with an F-150.
Tim d
Alpena
Ram
So dealers and owners have been dealing with this problem for over 2 years and all it takes is a battery replacement? Why didn't Ford fix this 2 years ago?
